Not the glue subject again!!!!! Options
Stupot
#1 Posted : 09 August 2012 15:38:21
Hi guys, sorry to go on about glue again but i'm still having problems with it.Took Tomick's advice & bought some 4 min Speed Epoxy from Deluxe Materials.I read the instructions & mixed it half & half.I held the parts together for 5 mins but it didn't bond.Am i doing something wrong? Should i add more hardener to the glue mix or more adhesive? The model is getting to the stage now where any mistakes will be visible.Thanks for your patience.Confused
dave1978
#2 Posted : 09 August 2012 17:08:56
I dont see why people are going for the complex stuff. Go to your local Wilkinsons and get the green tube "hard plastic glue", bonds in seconds, no trouble.
#3 Posted : 09 August 2012 17:46:33
Ditto....
I've used this stuff on plastics ranging from airfix-type kits right through to rigid stuff almost as hard as Perspex.
No probs.
"Sticks like sh-t to a blanket" as they say.
Roy.
Stupot
#4 Posted : 09 August 2012 20:10:11
Thanks for the advice.Will buy some & give it a go.
firefighter
#5 Posted : 10 August 2012 13:20:54
loctite super glue tube and brush simples.com it works a treat as this is my first build im a happy man with it as you only need a tiny little bit done and dusted
schueyking
#6 Posted : 10 August 2012 19:22:08
roymattblack wrote:
Ditto....
No probs.
Roy.
Does this glue have the 'bloom effect' though??Confused
ChrisBigGrin
This page was generated in 0.145 seconds.
