56 Pages «<4041424344>»
MWG build diary of the mighty Hood Options
#821 Posted : 28 August 2012 10:55:16
mark 2 wrote:
Hi Mike.
I just wanted to say how much i am enjoying this build and hope you are too BigGrin .
I would like to have done the Bismark Mad .
Maybe they would release it again.
Anyway i wont Flapper anymore.
Best regards my friend.
Hi Mark As regards Bismark maybe you can still buy Issues on ebay? but the Hood is enjoyable for me toBigGrin Regards Mike
S2ksean
#822 Posted : 28 August 2012 22:59:30
I see ya doing enhancements for the victory and the x section. Will u be doing any for this build?
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#823 Posted : 02 September 2012 11:55:40
Hi Sean, I have no plans to enhance the HoodBigGrin Thanks for asking Regards Mike
#824 Posted : 02 September 2012 13:38:48
ISSUE 50
Hi Team, here is the next episode of my build.
This is what we received:-
#825 Posted : 02 September 2012 13:40:38
ISSUE 50
Now we add the fet of parts left over from Issue 49:-
#826 Posted : 02 September 2012 13:43:57
ISSUE 50
If you follow the instructions you will not go far wrong.
Next job is to join the two halves of the turret together then do not forget to file off the 2 pins at the back:-
I use poly adhesive by the way
#827 Posted : 02 September 2012 13:47:29
ISSUE 50
Now fit the triangular parts 238 and 239:-
#828 Posted : 02 September 2012 13:56:37
ISSUE 50
Cut from the brass fret the parts you require for this part of the build:-
#829 Posted : 02 September 2012 13:59:53
ISSUE 50
Now for a tricky bit, as per the instructions drill a 1/2mm hole in the turret (central front) and fit part 240 in the hole PHEW:-
#830 Posted : 02 September 2012 14:03:45
ISSUE 50
Now its time to fit the ladder ( for all the fixing of the brass etch I am using Loctite Gel super glue)
Put a bend at each end:-
#831 Posted : 02 September 2012 14:05:54
ISSUE 50
Fix all the parts to the range finder (brass and plastic):-
#832 Posted : 02 September 2012 14:07:53
ISSUE 50
And the last job is to fit the Range finder to the Turret:-
#833 Posted : 02 September 2012 14:10:55
ISSUE 50
Thats all for this session, thanks for looking in, I will leave you with the photo of the completed 2nd TurrettBigGrin Questions and comments always welcome
Regards Mike
#834 Posted : 06 September 2012 23:10:44
ISSUE 51
Hi Team, this what we received:-
#835 Posted : 06 September 2012 23:13:17
ISSUE 51
Then I just followed the instructions:-
#836 Posted : 06 September 2012 23:16:09
ISSUE 51
Thats all this time Questions and comments welcomeBigGrin Regards Mike
#837 Posted : 06 September 2012 23:19:30
ISSUE 52
This is what we receive this week:-
#838 Posted : 06 September 2012 23:22:56
ISSUE 52
Following the instructions we fitted the parts together:-
#839 Posted : 06 September 2012 23:27:15
ISSUE 52
And there is more!!!!!:-
#840 Posted : 06 September 2012 23:33:05
ISSUE 52
And finally:-
Thats all for now thank you for looking in, Questions and comments WelcomeBigGrin
Guest (10)
This page was generated in 1.439 seconds.
