9 Pages <1234>»
MWG build diary of the HMS Victory X - Section Options
#21 Posted : 31 August 2012 22:08:30
ISSUE 121
The object of this weeks build is to form 4 x Ribs from the parts supplied, the instructions call for map pins to hold the parts in place untill the adhesive dries, again I preffered to use masking tape to do the same job, it worked perfectly, here are the 4 ribs:-
#22 Posted : 31 August 2012 22:12:09
ISSUE 121
Well Team thats this issue`s build complete.
Questions and comments welcomeBigGrin Thank you for looking inBigGrin Here are the for ribs finished:-
Mike
#23 Posted : 31 August 2012 22:12:48
Good to see another cross-section build kick off Cool
#24 Posted : 01 September 2012 11:29:31
Hi Mike,
Pleased to see you have started your build,is it just the two of us?.I know you will enjoy this build it all goes together well in my opinion, and I think a lot are missing out,this model gives a great insight in to how it was in there day can't wait for issue 126.
Kind Regards Trev.
#25 Posted : 01 September 2012 12:59:31
their will be a few more of us when de-ag decide to deliver to the distributors, I waiting for 121,122. to get started.
saintsman123
#26 Posted : 01 September 2012 17:11:57
you should have ordered from my newsagent karl
Come on you Jimmies
#27 Posted : 02 September 2012 11:35:12
tf64 wrote:
Hi Mike,
Kind Regards Trev.
Hi Trev your right, like you I believe it will be a nice surprise buildBigGrin Regards Mike
#28 Posted : 02 September 2012 17:06:10
ISSUE 122
Hi Team this my next build section, this is what we received:-
#29 Posted : 02 September 2012 17:10:54
ISSUE 122
The object of this issues build is to make the last three ribs which make up the Hull ( making 7 in total )
First up we cut all the parts from the fret and file and sand them:-
#30 Posted : 02 September 2012 17:14:28
ISSUE 122
The rib assembly plan I used in issue 121 was still in good shape so I was able to use it again:-
#31 Posted : 02 September 2012 17:17:37
ISSUE 122
Again I used masking tape to hold the parts of the ribs inplace not pins and built up the 3 ribs ,where ther was a join I supported it with a clamp:-
#32 Posted : 02 September 2012 17:20:59
ISSUE 122
Thats all this time thanks for looking inBigGrin as usual questions and comments are welcomeBigGrin Here are the 3 ribs completed:-
Regards Mike
#33 Posted : 07 September 2012 11:02:46
Hi Team, I will have details this weekend of my full mast with standard rigging enhancment in 1/72 scale.
If you are interested in this enhancement please email me (if you have my email address) or PM me, we need the usual quantity to make it viable, lead times are very goodBigGrin Regards Mike
#34 Posted : 07 September 2012 15:35:18
Hi Mike.
Great start. looking forward to seeing your progress.
IanCool
#35 Posted : 07 September 2012 17:52:32
ian smith wrote:
Hi Mike.
IanCool
Hi Ian Thank youBigGrin Regards Mike
#36 Posted : 09 September 2012 14:10:00
ISSUE 123
Hi Team this week we received:-
#37 Posted : 09 September 2012 14:13:51
ISSUE 123
I actually followed MR T`s Official build for this weeks work, and I found it very good, no more to be said here is the result:-
#38 Posted : 09 September 2012 14:17:36
ISSUE 123
Please take care with these frames they are very fragile, and you could easily break one, I all so removed all of the loose ash from the parts the adhesive will fix better and the jigs are a must use:-
#39 Posted : 09 September 2012 14:21:04
ISSUE 123
Thats all for this time thank you for looking inBigGrin Questions and comments welcomeBigGrin This is the progress up to now.
saintsman123
#40 Posted : 09 September 2012 14:44:50
where do you keep them all mike BigGrin
Come on you Jimmies
Guest (11)
9 Pages <1234>»
This page was generated in 0.485 seconds.
