gunport frames Options
davegreased55
#1 Posted : 06 September 2012 14:22:00
Rank: Newbie
i've noticed on other build diaries that i've seen that wood frames are to be used for the gun ports 12x12 four pieces.Mad and could not find metal frames anywhere in tomiks build diary.Confused
#2 Posted : 06 September 2012 14:34:59
You've lost me, the gun port frames are made up of 4 strips of wood rather than being metal
saintsman123
#3 Posted : 06 September 2012 15:39:46
hi dave
all the gunport frames are made from 2mmx2mm wood. a couple of builders used a square tubular material to give a perfect square.
Come on you Jimmies
This page was generated in 0.119 seconds.
