9 Pages <12345>»
MWG build diary of the HMS Victory X - Section Options
#41 Posted : 09 September 2012 17:00:56
Hi Mike,
Looking good received issue 126 Saturday can press on now.
Regards Trev.
#42 Posted : 09 September 2012 17:26:06
tf64 wrote:
Hi Mike,
Regards Trev.
Thanks Trev, I am really enjoying this build, I believe it will be an authentic when build when finished, as requested I have put your name on the list for the Full Mast enhancement. Regards Mike
#43 Posted : 09 September 2012 17:35:09
X- SECTION ENHANCEMENT UPDATE
Hi Team thank you to the members, who sent me a PM to be put on the Full Mast enhancment list,from the replys I have had this enhancment will be a goBigGrin
I have 4 more enhancements including a mast head lamp, copper tiles (with rivit lines)and boarding pikes for the main mast.
If any one wants to express an interest please send me a PM in the first instance
Kind regards
Mike
#44 Posted : 10 September 2012 21:39:51
ISSUE 124
Hi Team this is turning out to be a great Partwork, I am really enjoying it.
We received 5mm x 2mm planking, plus grating strips.
As advised in previous posts the timber has been badly cut, so I had some yard lengths in lime wood and I am using that, also I am not using map pins I am using my small clamps with a piece of timber under the jaws to stop the clamp marking the planking, this has worked very well.
At the same time I have used the Jigs that came in issue 123 to keep the ribs at the correct spacing while planking.
The first photo is of the Magazine and my new planking:-
#45 Posted : 10 September 2012 21:44:00
ISSUE 124
I followed the instuctions, and made the brace for stability, then proceeded to plank:-
saintsman123
#46 Posted : 10 September 2012 21:51:30
just watch the nasking tape at the top mike, you really want to wrap it round the very top dowel, otherwise you'll be taking it off a few times as you get near the top of the outside planking.
Come on you Jimmies
#47 Posted : 10 September 2012 21:52:33
ISSUE 124
And here is where I am upto at the moment:-
thanks for looking in, questions and comments welcomeBigGrin regards Mike
#48 Posted : 14 September 2012 15:30:36
ISSUE 124
Hi again, I have now finished issue 124 apart from sanding the plank edges;-
#49 Posted : 14 September 2012 15:39:50
ISSUE 124
Well team thats all this time thanks for looking in.
When this X section is finished I will be mounting it on a board and fixing it to a wall in the house.
I am posting up a range of enhancements for this build on the VICTORY BUILD DISCUSSION area later today with photos
Questions and comments welcomeBigGrin
Blackspear
#50 Posted : 14 September 2012 15:47:40
Looking really good Mike.
Craig
Jesus-Belzheim
#51 Posted : 14 September 2012 16:17:39
Neat work there Mike,
That looks very good ThumpUp
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
#52 Posted : 14 September 2012 16:21:13
Craig
Thank you CraigBigGrin Regards Mike
#53 Posted : 14 September 2012 16:22:16
Hi Peter I am really enjoying this BuildBigGrin Regards Mike
SennaMentalMe
#54 Posted : 14 September 2012 17:23:01
Hello Mike,
As you know, I don't build the ships on here but you said in your previous post that when this Cross-Section is finished you will be mounting it on a board and hanging it on your wall??
Just an idea here, but have you thought of mounting it on a plinth to support it's weight but with one of the open ends of the section butted tight to a mirror?? That way it will be reflected in the mirror and look TWICE the length when viewed from the front but also it will appear to have TWICE the amount of detail inside, albeit repeated?? I think it would look pretty cool myself!!
As I say just a thought but wanted to throw it in in case it was worthwhile?
Did you manage to order some of those aftermarket McLaren decals by the way??
All the best,
#55 Posted : 14 September 2012 18:48:24
SennaMentalMe wrote:
Hello Mike,
All the best,
Hi Kev thank you for your input thats a great idea, no not yet I could not access the site , I will keep trying.
Kind regards
MikeBigGrin
#56 Posted : 14 September 2012 18:53:02
Hi Team you can obtain a mountain of information on your X section by referring to:- THE ANATOMY OF A SHIP THE 100- gun ship VICTORY by John Mckay
Pages inparticular 70 to 83.
Also VICTORY 1765 by Jonathan Eastland lots of colour photos below decks
RegardsBigGrin Mike
#57 Posted : 14 September 2012 19:45:10
BigGrin Looking good Mike as usual top marks for the diary and buildCool
#58 Posted : 14 September 2012 20:19:35
[quote=arpurchase]BigGrin Looking good Mike as usual top marks for the diary and buildCool [/quote)
Thanks Andy your comments are much appreciatedBigGrin Regards Mike
#59 Posted : 16 September 2012 20:33:12
ISSUE 125 BUILD
Hi Team here is my latest build on the X section, this is what we received this week.
I have purchased new wood 1.5mm x 5mm I prefer to use it;-
#60 Posted : 16 September 2012 20:39:35
ISSUE 125 BUILD
Then I followed the instruction and planked the inside to just under the deck supports.
I Bevelled the planks on the bend of the Hull,I used adhesive on the edges of the planks also, again I am using planks (I do not like map pins) I have no marks with the clamps:-
Guest (12)
9 Pages <12345>»
This page was generated in 0.326 seconds.
