Hi Mike, Looking good received issue 126 Saturday can press on now. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
tf64 wrote:Hi Mike, Looking good received issue 126 Saturday can press on now.
Regards Trev. Thanks Trev, I am really enjoying this build, I believe it will be an authentic when build when finished, as requested I have put your name on the list for the Full Mast enhancement. Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
X- SECTION ENHANCEMENT UPDATE Hi Team thank you to the members, who sent me a PM to be put on the Full Mast enhancment list,from the replys I have had this enhancment will be a go I have 4 more enhancements including a mast head lamp, copper tiles (with rivit lines)and boarding pikes for the main mast. If any one wants to express an interest please send me a PM in the first instance Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 124 Hi Team this is turning out to be a great Partwork, I am really enjoying it. We received 5mm x 2mm planking, plus grating strips. As advised in previous posts the timber has been badly cut, so I had some yard lengths in lime wood and I am using that, also I am not using map pins I am using my small clamps with a piece of timber under the jaws to stop the clamp marking the planking, this has worked very well. At the same time I have used the Jigs that came in issue 123 to keep the ribs at the correct spacing while planking. The first photo is of the Magazine and my new planking:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 124 I followed the instuctions, and made the brace for stability, then proceeded to plank:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 30/01/2011 Posts: 865 Points: 2,410 Location: Cambs
just watch the nasking tape at the top mike, you really want to wrap it round the very top dowel, otherwise you'll be taking it off a few times as you get near the top of the outside planking. Come on you Jimmies
ISSUE 124 And here is where I am upto at the moment:- thanks for looking in, questions and comments welcome  regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 124 Hi again, I have now finished issue 124 apart from sanding the plank edges;- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 124 Well team thats all this time thanks for looking in. When this X section is finished I will be mounting it on a board and fixing it to a wall in the house. I am posting up a range of enhancements for this build on the VICTORY BUILD DISCUSSION area later today with photos Questions and comments welcome MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 14/12/2010 Posts: 142 Points: 425 Location: Grantham
Looking really good Mike.
Craig
 Rank: Pro   Groups: Joined: 04/05/2012 Posts: 362 Points: 1,089
Neat work there Mike, That looks very good
Blackspear wrote:Looking really good Mike.
Craig
Thank you Craig  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Jesus-Belzheim wrote:Neat work there Mike, That looks very good Hi Peter I am really enjoying this Build  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hello Mike,
As you know, I don't build the ships on here but you said in your previous post that when this Cross-Section is finished you will be mounting it on a board and hanging it on your wall??
Just an idea here, but have you thought of mounting it on a plinth to support it's weight but with one of the open ends of the section butted tight to a mirror?? That way it will be reflected in the mirror and look TWICE the length when viewed from the front but also it will appear to have TWICE the amount of detail inside, albeit repeated?? I think it would look pretty cool myself!!
As I say just a thought but wanted to throw it in in case it was worthwhile?
Did you manage to order some of those aftermarket McLaren decals by the way??
All the best,
Kev
SennaMentalMe wrote:Hello Mike,
All the best,
Kev Hi Kev thank you for your input thats a great idea, no not yet I could not access the site , I will keep trying. Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hi Team you can obtain a mountain of information on your X section by referring to:- THE ANATOMY OF A SHIP THE 100- gun ship VICTORY by John Mckay Pages inparticular 70 to 83. Also VICTORY 1765 by Jonathan Eastland lots of colour photos below decks Regards  Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Looking good Mike as usual top marks for the diary and build Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
[quote=arpurchase]  Looking good Mike as usual top marks for the diary and build  [/quote) Thanks Andy your comments are much appreciated  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 125 BUILD Hi Team here is my latest build on the X section, this is what we received this week. I have purchased new wood 1.5mm x 5mm I prefer to use it;- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 125 BUILD Then I followed the instruction and planked the inside to just under the deck supports. I Bevelled the planks on the bend of the Hull,I used adhesive on the edges of the planks also, again I am using planks (I do not like map pins) I have no marks with the clamps:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Guest (27)
