Sovereign armaments Options
#1 Posted : 16 September 2012 20:31:59
When she was first fitted out, the guns of the Sovereign of the Seas were supplied by John Browne, the son of a gunfounding family. His father, Thomas Browne, was the Founder of Iron Ordnance to Elizabeth I and James I. Although not apprenticed in iron making, John took over his father’s patents in 1615 when he was appointed one of the King’s Founder of Iron Ordnance afloat and ashore with a wage of eight pence – 7½p, worth £7.20 today – a day. With ironworks in Brenchley and Horsmonden in Kent, he was aided by a decree in 1619 that confined gunfounding to Kent and Sussex, where he also had interests.
In the 1620s, Browne developed a new cannon known as the drake. Weighing a third less than earlier cannon firing the same weight of shot, these allowed ships to be more heavily armed. Originally a Dutch design, the drake had a shorter barrel that conventional cannon with a bore that was wider at the muzzle than at the back of the chamber. It used only two-thirds of the powder of its conventional counterpart and was easier to handle when firing repeatedly. While the velocity and range suffered, at close quarters it was more devastating than a conventional piece.
Browne received a reward of £200 – £19,000 today – for the introduction of the dake. But in 1635 he had to pay Charles I £12,000 – over £1 million today – for a patent allowing him to make, sell and transport ordinance and shot. Browne was selling guns to the Dutch and Spanish, as well as the crown, and Charles effectively became a partner in his export business. This was tightly regulated. All ordnance could only be landed at, or shipped from, the wharf at the Tower of London. Proving was done in Ratcliff Fields, Stepney, and all sales took place in East Smithfield. Guns also had to carry at least two letters of the founder’s name, the year of manufacture and the weight of the piece.
His arrangement with the king also brought Browne honours. He was granted a coat of arms that consisted of “Gules a passant and a Chief Or” – “Gules” is red, the “Chief” is the top third of the shield and it was “Or” or gold. A Griffin is half-lion, half-eagle and “passant” means that walking, with its face in profile.
His crest was even more elaborate: “Upon a Helm with a Wreath Or and Gules. A Falcon wings inverted and addorsed proper armed legged and belled Or preying upon a Mallard’s Wing Proper, Mantled Gules doubled Argent.”
In 1637, Browne paid out another £1,000 to adapt his foundry to cast the guns for the Sovereign of the Seas. Though the iron works is long gone, the Furnace Pond came still be seen outside the village of Horsmonden. The works were well sited. The River Medway was handy to transport the guns and the area was rich in timber for fuel. However, in 1637, the nearby village of Cranbrook made a complaint that John Browne had purloined most of their woodlands to the detriment of their craft of weaving. But Browne position was unassailable and he was appointed the King’s Gunfounder in 1640.
Browne made the guns for the Sovereign of the Seas by the lost-wax process. He made a full-size model of the piece in wood, including all the decoration and annotation – and the trunnions on either side that rested on the gun carriage. These were placed slightly behind the centre of gravity so that the gun would naturally elevate.
The wooden model was then used to made a mould, which was used to cast a wax replica. This is then smeared with lard or grease and seared with a clay paste mixed with hair, flax and horse droppings. When turned over a fire, the clay harden, while the wax drained away. The shell was then strengthened by iron rods and thickened with the addition of more clay.
A core was made by a similar clay mixture smeared over an iron spindle bound with rope. The outer surface was then smoothed, dried and burnished to the diameter given by a template. The shell was placed in a pit with the muzzle end upwards and the core was inserted. Then molten metal was poured in. Once it had solidified and cooled, the mould was broken and removed. The outside was smoothed with a chisel on a lathe, the inside reamed, and the powder hole or vent drilled.
The guns were seated in a carriage. The sides were usually made of elm which was resistant to splintering if struck by flying debris. The cross beams were oak. Because of the narrowing diameter of the gun, the sides – or cheeks – of the gun carriage sloped towards each other at the fore end. The carriage was strengthened with iron straps. The small carriage wheels were also elm and mounted on an iron axle.
The Sovereign of the Seas had 118 gun ports and only 102 guns. The shape of the bow meant that the foremost gun ports on the lower gun deck were blocked by the anchor cable. Consequently, the fore chase – the guns facing forward – occupied the next ports. There were two demi-cannon drakes – one port, one starboard – some 11.5 feet long (3.5m), weighing together five tons (4,536kg). They had a bore of 6.4 to 6.75 inches (16.2–17.1cm) and fired a shot weighing 32 to 36 pounds (14.5–16.3kg), using around ten pounds of gunpowder.
In the third ports from the bow, there were two 11-foot (3.4m) demi-cannon drakes weighing, together, 4.3 tons (3,901kg). Behind them were twenty VII drakes, nine feet long, and weighing in all 45.7 tons (41,458kg). In the third port from the stern were two more 11-foot (3.4m) demi-cannon drakes weighing, together, 4.3 tons (3.901kg). The last two ports on either side were occupied by the stern chase – four 10.5-foot (3.2m) demi-cannon drakes weighing a total of 11.4 tons (10,342kg).
The middle gun deck had heavy fortified culverins – that is, guns short for their bore – fore and aft. There were two 11.5-foot (3.5m) pieces, weighing 4.8 tons (4,354kg), in the fore chase; four 11.5-foot (3.5m) pieces, weighing 10.2 tons (9,253kg), in the stern chase. Immediately behind the fore chase were two demi-culverin drakes, eight to nine foot (2.4–2.7m) long, weighing some 1.9 tons (1,724kg). Then came twenty-two 9.5-foot (2.9m) culverin drakes weighing a total of 30.4 tons (27,578kg).
On the upper gun deck there were two 10-foot (3m) fortified demi-culverins in the fore chase and two in the stern chase, both pairs weighing 2.8 tons (2,540kg). Between them there were twenty-two demi-culverin drakes, eight to nine feet (2.4–2.7m) long, weighing over 21 tons (19,000kg) in total.
There were eight-to-nine-foot (2.4–2.7m) demi-culverin drakes weighing 7.7 tons (6,985kg) in the forecastle; another six weighing 5.7 tons (5,170kg) on the half-deck. The quarter-deck carried two six-foot demi-culverin drake cutts – a cutt, again, being a shorter version of a gun – weighing 16 hundredweight (726kg). Then there were another two six-foot culverin cutts, weighing 1.3 tons (1,179kg), aft of the forecastle bulkhead. In all, the Sovereign of the Seas carried 155.9 tons (141,430kg) of guns – and that did not include the weight of the gun carriages. Altogether they cost £26,441 13s 6d – or £2,268,695.72 in today’s money – including £3 (£257.50) per piece to have the Tudor rose, a crown and the motto: “Carolvs Edgari sceptrvm aqvarum” – “Charles has established Edgar’s sceptre of the waters” – engraved on them. The gun carriages, made by Matthew Banks, Master Carpenter for the Office of Ordinance, cost another £558 11s 8d – £47,926.45 today.
The shot was made from cast iron or lead cast around a stone core – five parts lead to one part stone. This ratio made the lead-and-stone shot roughly the same weight as a cast-iron cannon ball of the same diameter.
The shot was made slightly smaller than the diameter of the barrel. This difference is known as the windage. During the sixteenth century the windage was kept at a constant 0.25 inches (0.635cm). But in the seventeenth century the bore divided by the diameter of the shot was fixed at 20:21 for English pieces or 27/26 for French pieces.
The gunpowder, or black powder, used as a propellant was a mixture of charcoal, sulphur and saltpetre – that is, potassium nitrate. It was manufactured under licence at Ospringe, near Faversham in Kent. The charcoal was produced locally, while the sulphur came from Sicily and Italy, and the saltpetre from Italy and India. The mills were on a tidal creek, making it easy to bring in the imported ingredient. Running water in the creek also supplied the power to grind the powder. Then it could be transported by boat to London, the arsenals along the Medway and the Channel ports.
Saltpetre was also produced locally from bird droppings. In 1634, Francis Vincent of Canterbury was appointed official “saltpetre man” for Kent, Sussex and Surrey, required to produce six hundredweights (272kg) a week. His main source was dovecotes in Kent. The soil from the floor was mixed with water and filtered through clean sand. Pure saltpetre was then crystallized out of the solution.
Gunpowder was made in Ospringe from 1560 to 1925. The mills there were owned by Thomas Judd who produced two tons of gunpowder a week in 1653. More was made in Chilworth in Surrey from 1635 to 1920.
While the powder was being milled using a large metal mortar and pestles, it was dampened by fresh water, vinegar or brandy to reduce the chance of spontaneous combustion. Finely milled gunpowder was called serpentine and used in the vent to ignite the main charge, or in small arms. The rest of the gunpowder was corned – dampened with water it was pressed through thick parchment with small holes in it to produce grains of a uniform size. These would not be compressed when tamped in the barrel. If the powder was too tightly packed, it excluded the air and, without oxygen, the gunpowder would not ignite. Corned gunpowder produced greater power, resulting in a higher muzzle velocity and greater range.
The powder was supplied in wooden barrels with copper, rather than iron, bands. This reduced the chances of producing a spark. Vinegar or brandy was also added to powder to prevent the powder deteriorating if seawater soaked into the wood.
The Sovereign of the Seas carried 330 kegs of powder, along with 2,850 round shot, 720 double-headed shot, 300 muskets, twenty blunderbusses, 200 pikes and 100 hatchets.
It is not entirely clear what happened to the cannon after the Sovereign of the Seas was destroyed. One demi-culverin drake sat at the northwest corner of Horseguards Parade in London for many years. In 1917, it was in store at the Rotunda, Woolwich, then it was moved to Chatham Dockyard. Since 2000 it has been on display at the Royal Artillery Museum in Woolwich. Engraved on it is: “JOHN BROWNE MADE THIS PEECE ANO, 1638” – along with the rose, crown and motto.
In the Royal Armouries in Leeds, there is a four-pounder with the Tudor rose and the letters C.R. – Carolus Rex – inscribed on it, along with the words: “CAST IN THE PRESENCE OF HIS MAJ OCTO THE FIFTH 1638, MOVNTIOY EARLE OF NEWPORT M GENERALL OF THE ORDNANCE. JOHN BROWNE MADE THIS PEECE.” Thought to be one of the Sovereign of the Seas’ original guns, it also saw service at the dockyards in Deptford in the Dutch attack of 1667.
The Royal Armouries has another piece with similar markings which was exhibited at the Royal Naval Exhibition in Chelsea in 1891. Until 1930 it was at the Rotunda Museum in Woolwich before being transferred to the Royal Armouries. However, neither of these two guns is thought to have been part of the Sovereign of the Seas’ main armament. Rather they may have been signal guns.
#2 Posted : 16 September 2012 20:59:09
Hi Mr T thank you for taking the time to relay this info to us BigGrin Really good data Regards Mike
#3 Posted : 16 September 2012 21:14:07
Great piece of work Mr T very informativeCool
#4 Posted : 16 September 2012 21:14:23
Fantastic piece of info Mr.T...It made fascinating reading..Thank you!! ThumpUp
philjaps1
#5 Posted : 16 September 2012 22:55:09
Good post Tomick - thanks for tsking the time to put it together
phil,
jay7792
#6 Posted : 17 September 2012 04:42:07
Thanks for the post Tomick, very informative.BigGrin
Especially knowing that I literally live a 5 minute walk away from Ospringe where the black powder was made!!
Jay
_____________________________________
Currently building:-
Deagostini HMS Victory
Amati Black Pearl
Mamoli HMS Victory 1:90 Scale
Caldercraft HMS Victory 1:72
Gus W
#7 Posted : 17 September 2012 09:06:54
Very interesting piece Mr T. Many thanks.
Currently Building:
Eaglemoss HMB Endeavour
De Agostini Sovereign of the Seas
Pietro
#8 Posted : 17 September 2012 21:17:43
Great article, always wondered how the cannons were made! I've been to the ruins of the gunpowder works in Chilworth as I don't live far away - here's some more info:
http://www.stmarthaparis...history/gunpowder-mills
Pete
rossi
#9 Posted : 18 September 2012 20:08:37
Thanks for that very interesting article.I will never look at a dove in quite the same way again BigGrin
coolbanana
#10 Posted : 18 September 2012 23:58:47
Rank: Amateur Level 1
Thank you great stuff. Its always nice to be a bit more informed about what one is building.
#11 Posted : 19 September 2012 09:36:23
You might also be interested in Thomas Heywood's description of the Sovereign, who was responsible for much of the ship's ornamentation.
In 1637, when she was launched, he published A True Description of His Majesties Royall Ship, later called A true Description of his Majesties royall and most stately Ship called the Sovereign of the Seas.
In it, he maintained that the Sovereign was part of the great story of maritime architecture beginning with Noah’s Ark and the Argo, which Jason sailed on in pursuit of the Golden Fleece. Along with engravings of the Sovereign and her ornamentation, Heywood gives a résumé of the doings of King Edgar and his navy. This seen as the forerunner of Charles I’s navy, whose crowning glory was now the Sovereign of the Seas.
Heywood's description of the great ship itself:
“I began at the Beak-head, where I desire you to take notice, that upon the stemme-head there is Cupid, or a child resembling him, bestriding, and bridling a Lyon, which importeth, that sufferance may curbe Insolence, and Innocence restraine violence; which alludeth to the great mercy of the King, whose Type is a proper Embleme of that great Majesty, whose Mercy is above all his Workes.
On the Bulk-head right forward, stand six severall Statues in sundry postures, their Figures representing Consilium, that is, Counsell: Cura, that is, Care: Conamen, or industry, and unanimous indeavour in one compartment: Counsell holding in her hand a closed or folded Scrole; Care a Sea-compasse; Conamen, or Industry, a Lint-stock fired. Upon the other, to correspond with the former, Vis, or Vertue, a sphearicall Globe: and Victoria, or Victory, a wreath of Lawrell. The Moral is, that in all high Enterprizes there ought to be first Counsell to undertake; then Care, to manage; and Industry, to performe; and in the next place, where there is ability and strength to oppose, and Vertue to direct, Victory consequently is alwayes at hand ready to crowne the undertaking.
Upon the Hances of the waste [the rising curve from the waist of the ship to the quarterdeck] are foure Figures with their severall properties: Jupiter riding upon an Eagle, with his Trisulk (from which hee darteth Thunder) in his hand; Mars with his Sword and Target, a Foxe being his Embleme: Neptune with his Sea-horse, Dolphin, and Trident: and lastly Aeolus upon a Camelion (a beast that liveth onley by the Ayre) with the foure Windes, his Ministers or Agents, the East, call’d Eurus, Subsolanus and Apeliotes: the North-winde, Septemtrio, Aquilo, or Boreas: the West, Zephrus, Favonius, Lybs, and Africus: the South, Auster, or Notus.
I come now to the Stearne, where you may perceive up the upright of the upper Counter, standeth Victory in the middle of the Frontispiece, with this general Motto, Validis incumbite remis: It is so plaine, that I shall not need to give it any English interpretation: Her wings are equally disply’d; on one Arme she weareth a Crowne, on the other a Laurell, which imply Riches and Honour: in her two hands she holdeth two Mottoes; her right hand, which pointeth to Jason, beares this Inscription, Nava, (which word howsoever by some, and those not the least opinionated of themselves, mistaken) was absolutely extermin’d, and excommunicated from all Grammaticall Construction, nay, Jurisdiction; for they would not allow it to be Verbe, or Adverbe, Substantive, nor Adjective: and for this I have not onely behind my back bin challenged, but even Viva voce taxed, as one that had writ at randum, and that which I understood not. But to give the world a plenary satisfaction, and that it was rather their Criticisme, than my ignorance, I intreate thee Reader, but to examine Riders last Edition of his Dictionary, corrected, and greatly augmented by Mr. Francis Holy-oke, and he shall there read Navo, navas, (and therefore consequently nava in the Imperative Mood) ex navus, that is, to imploy with all ones power, to act, to ayde, to helpe, to indeavour with all diligence and industry; and therefore not unproperly may Victory point to Jason, being figured with his Oare in his hand, as being the prime Argonaut, and say Nava, or more plainely, Operam nava; for in those Emblematicall Mottoes quod subintelligitur, non deest. Shee pointeth to Hercules on the sinister side, with his club in his hand, with this Mottto, Clava; as if she should say, O Hercules, be thou as valiant with thy Club upon the Land, as Jason is industrious with his Oare upon the Water. Hercules againe pointing to Aeolus, the god of Windes, saith Flato; who answereth him againe, Flo: Jason pointing to Neptune, the god of the Seas, (riding upon a Sea-horse) saith Faveto; to whom Neptune answereth, No: These words Flo, and No, were also much excepted at, as if there had beene no such Latine words, till some better examining their Grammar Rules found out Flo, flas, flavi, proper to Aeolus, and No, nas, navi, to Neptune, &c.
In the lower Counter of the Sterne, on either side of the Helme is this Inscription,
Qui mare, qui fluctus, ventos, naves[que] gubernat, Sospitet hanc Arcam Carole magne tuam.
Translated:
"He who Seas, Windes, and Navies doth protect, Great Charles, thy great Ship in her course direct."
There are other things in this Vessell worthy remarke, at least, if not admiration; namely, that one Tree, or Oake made foure of the principall beames of this great Ship, which was Forty foure foote of strong and serviceable Timber in length, three foote Diameter at the top, and Ten foot Diameter at the stubbe or bottome.
Another, (as worthy of especiall Observation is) that one peece of Timber which made the Kel-son, was so great, and weighty, that 28. Oxen, and 4. Horses with much difficulty drew it from the place where it grew, and from whence it was cut downe, unto the water-side.
There is one thing above all these, for the World to take especiall notice of, that shee is, besides her Tunnage, just so many Tuns in burden, as their have beene Yeeres since our Blessed Saviours Incarnation, namely, 1637. and not one under, or over: A most happy Omen, which though it was not at the first projected, or intended, is now by true computation found so to happen.
It would bee too tedious to insist upon every Ornament belonging to this incomparable Vessel, yet thus much concerning Her outward appearance. She hath two Galleries of a side, and all of most curious carved Worke, and all the sides of the ship are carved also with Tropies of Artillery and Types of honour, as well belonging to Land as Sea, with Symboles, Emblemes, and Impresses appertaining to the Art of Navigation: as also their two sacred Majesties Badges of Honour, Armes, Eschutchions, &c. with severall Angels holding their Letters in Compartments: all which workes are gilded quite over, and no other but gold and blacke to bee seene about her. And thus much in a succinct way I have delivered unto you concerning her inward and outward Decorements. I came now to Discribe her in her exact Dimension.
Her Length by the Keele, is 128 foot or there about, within some few inches. Her mayne breadth or widenesse from side to side 48. foote. Her utmost length from the fore-end of the Beake-head, unto the after end of the Sterne, a prora ad puppim 232. foote, she is in height from the bottome of her Keele to the top of her Lanthorne seaventy sixe foote, she beareth five Lanthornes, the biggest of which will hold ten persons to stand upright, and without shouldring or pressing one the other.
She hath three flush Deckes, and a Fore-Castle, an halfe Decke, a quarter Decke, and a round-house. Her lower Tyre hath thirty ports, which are to be furnished with Demy-Cannon and whole Cannon through out, (being able to beare them). Her middle Tyre hath also thirty ports for Demi-Culverin, and whole Culverin: Her third Tyre hath Twentie sixe Ports for other Ordnance, her fore-Castle hath twelve ports, and her halfe Decke hath fourteene ports; She hath thirteene or foureteen ports more within Board for murdering peeces, besides a great many Loope holes out of the Cabins for Musket shot. She carrieth moreover ten peeces of chase Ornance in her, right forward; and ten right aff, that is according to Land-service in the front and the reare. She carrieth eleaven Anchors, one of them weighing foure thousand foure hundred, &c. and according to these are her Cables, Mastes, Sayles, Cordage; which considered together, seeing his Majesty is at this infinite charge, both for the honour of this Nation, and the security of his Kingdome, it should bee a great spur and incouragement to all his faithful and loving Subjects to bee liberall and willing Contributaries towards the Ship-money.
I come now to give you a particular Denomination of the prime Worke-men imployed in this inimitable Fabricke; as first Captayne Phines Pett, Over-seer of the Worke, and one of the principal Officers of his Majesties Navy; whose Ancestors, as Father, Grand-father, and Great-Grand-father, for the space of two hundred yeares and upwards, have continued in the same Name, Officers and Architectures in the Royall Navy; of whose knowledge, experience, and judgement, I can not render a merited Character.
The Maister Builded is young M. Peter Pett, the most ingenious sonne of so much improoved a Father, who before he was full five and twenty yeares of age, made the Model, and since hath perfected the worke, which hath won not only the approbation but admiration of all men, of whom I may truely say, as Horace did of Argus, that famous Ship-Master, (Who built the great Argo in which the Grecian Princesse Rowed through the Hellespont, to fetch the golden Fleece from Colchos)."
SandyM
#12 Posted : 19 September 2012 11:00:32
Thanks a lot Mr T.
A very interesting read and a lot to digest.
Various balsa aircraft both rubber powered and RC
Billing Jyland
Billing Wasa
Billing Dutch Royal Barge (gold medal winner Germany 1975)
Scratch built HMS Victory using HMSO plans hull size 26"
Scratch built Yamato Hull size 8'8"
De Pardo HMS Bounty
Current build Sovereign of the Seas
#13 Posted : 19 September 2012 11:38:40
Thanks Mr T for another very useful postBigGrin Regards Mike
This page was generated in 0.154 seconds.
