 Rank: Vice-Master       Groups: Registered
Joined: 21/04/2012 Posts: 747 Points: 2,233 Location: Tokyo, Japan
Hi Andy! I'm very glad to see your satisfactory building of the Akagi model. I have noticed that your lift has 4 free wires. I guess DeAGOSTINI Uk does not also explain how to handle them as DeAGOSTINI Japan did not. Since explanations from the DeAGOSTINI Japan were (are?) doubtful for me, I also left the 4 wires free for several period as shown in a attached picture as you did. But I found there were no severe pit falls about these 4 wires. I attached the wires at proper positions. Best Regards, Yutaro Yutaro HONMA attached the following image(s): DeAGOSTINI 1/250 the YAMATO, 1/250 the AKAGI. Hasegawa Co. 1/350 Battle ship NGATO, 1/350 Aircraft carrier Akagi, Battle ship MIKASA. Water line series 1/700 Battle ship YAMATO, HIEI, YAMASHIRO, Aircraft carrier HIRYU,TAIHO, Heavy Cruiser Myoukou, Ashigara, Nachi, Haguro & others.
 Hi Yaturo The build instructions say to cut these wires off at the top wheel but i knew these wires were where the lift is attached so i left them uncut for that reason.As for the enjoyment of the build all i will say is she is certainly a chalenge in parts regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Not much happening as im waiting for this months lift parts before i can resume the build on the hangars,but i added the bilge keels for something to do the screws and rudders will be added at the end of the build. As usssual all questions/comments are welcome regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 06/08/2011 Posts: 480 Points: 1,421 Location: Galway
Hi Andy, looking good as always
 Thanks Ger C Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy The hull and bilge keels look beautiful. I guess the painting process is closing to your Akagi. I'm waiting for next photos. Best Regards, Yutaro DeAGOSTINI 1/250 the YAMATO, 1/250 the AKAGI. Hasegawa Co. 1/350 Battle ship NGATO, 1/350 Aircraft carrier Akagi, Battle ship MIKASA. Water line series 1/700 Battle ship YAMATO, HIEI, YAMASHIRO, Aircraft carrier HIRYU,TAIHO, Heavy Cruiser Myoukou, Ashigara, Nachi, Haguro & others.
 Thank you Yaturo Still have loads to do on the hangars yet regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy really great work, love it  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Thanks Mike Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All heres a couple of pics of the last stern lift]excuse the wet paint]  .This is the smallest and most chalenging lift to fit everything into,as space is at a premium.I had to do a fair amount of fettling on the motor components bases to get everything to fit,but as you can see it is possible to get it in with a little bit of thought. If like me you decide to use Amati's portholes to enhance your build the 1.5 porthole count is 66 and the 2mm is 496, so you will need 1 pack of 1.5 mm[aprox 100 per pack for 1.5 and 2.0 mm]and 5 packs of the 2mm portholes,i obtained mine from CMB but this will not be cheap option as you wont see much change out of £46.00 with post and packing. I can now continue with the fitting of the stern hangars and then some serious painting of the internal walls/floor.After that theres the portholes to add and the deguasing cable,i will be using plastic strip for this again as in my Yamato build and then more painting of the external hull.As always all questions/comments are welcome regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 04/04/2012 Posts: 4 Points: 12 Location: leicestershire
Hi could someone please send me a link for the build insructions for the second instalment to the akagi
simon walton wrote:Hi could someone please send me a link for the build insructions for the second instalment to the akagi you should have received an email stating that it was available, if not then your best option is to contact cs
 Thanks Ger C for your kind words, Simon if you were able to download the 1st set of instructions use that e-mail that you were sent at the time to renter the download page,if it still says Akagi 1 only then do this, in bottom left of download page there is a log out button[very easy to miss] log out using this then reenter your passcode and the 2nd set of instructions should then appear ready for download.Hope this helps regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All More progress to post ,i have now finished the 3 lift platforms just a bit more paint to add here.The hangars are all now in place and some of the cappings have been added some filler will be needed in places to tidy things up,next i will be busy painting up the hanger internal walls/decks then its the portholes to add.As ussual all comments and questions are welcome regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hello Andy, Watching with intrest looking good Andy. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Joined: 30/01/2011 Posts: 865 Points: 2,410 Location: Cambs
looking good andy, i've got 8 packs now so will be starting quite soon. Come on you Jimmies
 Thanks for looking in Trev your comments are apreciated and Saintsman thanks also, so when are we to see your build diary m8 regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy, I love this build  I know its not easy but you are doing a great job  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hi Andy! Your work of lifts were very fine. Motors, gears and wires seems realistic! By the way, as I wrote in another topic, DeAGOSTINI Japan closed this part work without showing us how to fix the floors of the lifts. I recommend you to make some kinds of stoppers for the floors. Best Regards, Yutaro DeAGOSTINI 1/250 the YAMATO, 1/250 the AKAGI. Hasegawa Co. 1/350 Battle ship NGATO, 1/350 Aircraft carrier Akagi, Battle ship MIKASA. Water line series 1/700 Battle ship YAMATO, HIEI, YAMASHIRO, Aircraft carrier HIRYU,TAIHO, Heavy Cruiser Myoukou, Ashigara, Nachi, Haguro & others.
Guest (15)
