Anyone know where I can place a rain sensor Options
driving4life
#1 Posted : 22 September 2012 19:54:25
Rank: Amateur Level 1
Recently I was thinking of placing a switch into my led rain light circuit, however I realised that water is a great conductor of electricity and thus decided upon making a rain sensor, thus would not need a switch.
I need your help of where I could think of placing the sensor. I was thinking of slightly poking it out near the wooden plank, in the underside.
the sensor will look something like this but much smaller.
Warthog
#2 Posted : 23 September 2012 12:24:26
So to activate it you need to add water? Ok... sounds like a good idea at first but that means you will have to put water near your model every time you want to show it working.. if so then I would suggest placing it as far as possible like in the base of a case if your going to put it in that.. or near the top so that when you add a drop the light comes on but its easy to clean up after...
Spencer
This page was generated in 0.133 seconds.
