Issue 113, Brass Wire too short? Options
Iain001
#1 Posted : 25 September 2012 15:31:45
Rank: Beginner Level 3
Hi,
In the parts list for issue 113 it states that the brass wire should be 150mm long, however, upon measuring it came out at just 100mm long. I informed Deagostini who sent me another issue 113. This time upon arrival the parts bag had been torn open along the top and resealed using sellotape. Upon measureing the brass wire, it came out this time at 120mm, still short of the 150mm.
Can anyone shed any light onto if the required length is 150mm or is there a misprint in the mag please.
Thanks
Iain
#2 Posted : 25 September 2012 15:42:33
hi Ian,the wire is long enough,it is used for making a hook when you've tied it round a block in issue 114,check uncle tom's official build.
http://forum.model-space....aspx?g=posts&t=4270
Iain001
#3 Posted : 25 September 2012 15:52:39
Thanks Karl, very much appreciate your speedy reply, at least I dont have to contact cs again.
BigGrin
This page was generated in 0.121 seconds.
