ISSUE 127 BUILD and the parts we use at this stage are used to forme the shot locker and pump well, here they are:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 127 BUILD Following the instructions I built the item:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 127 BUILD at the point I deviated from the instructions and changed the lip that goes across the back of the shot locker, from the ply supplied to a piece of walnut see the next photo:- I intend to cover the pump well and shot locker in 5mm x 1/2mm walnut, It has a grain like scale oak and I will leave it rough looking without sanding. MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 127 BUILD Well team thats it for this session, thanks for looking in  Question and comments welcome. I will leave you with the photo of what we have achieved this time:- Regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hi Mike, Nice work, good presentation,coming on well. Kind Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Joined: 02/09/2012 Posts: 73 Points: 225 Location: York
MWG wrote:Gus W wrote:MWG wrote:Gus W wrote: Are those the Caldercraft cannons Mike?
Hi Gus, I have the made as a kit  Regards Mike They look very nice Mike. I am after some replacements for the Endeavour, so I just wondered if they were the Caldercraft 4 pounders Hi Gus I have sourced cannons and a 10 spoke ships wheel, in brass etch, size is 24mm ( a better scale size) for the Endeavour because I wanted them for my build PM your email address and I will send Info and prices. Regards Mike Thanks Mike, will do. Currently Building:
Eaglemoss HMB Endeavour De Agostini Sovereign of the Seas
tf64 wrote:Hi Mike, Nice work, good presentation,coming on well.
Kind Regards Trev. Hi Trev thank you, always a pleasure to hear from you  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Rank: Pro   Groups: Joined: 04/05/2012 Posts: 362 Points: 1,089
A very nice work there Mike
Jesus-Belzheim wrote:A very nice work there Mike Hi Peter thank you for that  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Top work as ussual Mike Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
arpurchase wrote: Top work as ussual Mike Thanks Andy much appreciated  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
looking good mike, nice clean build. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
ian smith wrote:looking good mike, nice clean build. Ian Hi Ian thank you  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 128 BUILD Hi Team, I have not posted on this build for a while, as many of you will know this is one of my favourite builds with lots of scope for enhancements and modifications, but more about those later. In this issue the object is to construct the main hull supports, these are made up of dedicated parts, I followed the instructions at this point:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 128 BUILD 1st MODIFICATION In the last picture I was not happy with the ends of the ply being on show so I decided to sheath the beems with 5 x 1/2mm walnut I have purchased to second plank the Victory, the grain is the nearest I have seen to simulate oak at this scale. I cut some pieces and soaked them in hot water then clamped them onto the wood while wet but no adhesive, have a look:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 128 BUILD The sheathing will dry and the shape will be formed ready for the adhesive, I will show you the result next time. 2nd MODIFICATION Next I saw from the Antatomy of the ship that a different limber configuration supporting the first deck was needed so I added a beam 3mm x 5mm plus 2 extra 2mm x 5mm stris under it, here it is:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 128 BUILD More of this 2 nd MOD next time, but I did have to trim the big hull beams to fit at this point:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 128 BUILD 3rd MODIFICATION I decided to sheath the shot locker and pump well with the same walnut, I am very happy with the result:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 128 BUILD Well thats all for now, I have not finished this issues build but I thought you would like to see the progress. thanks for looking in  as usual if you would like more info on what I am doing with this build do not hesitate to ask or comment I will leave you with the 4th MODIFICATION ---- sheathing the mast base so you do not see the ends of the ply grain,( the sheaths were soaked in hot water first) Regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 128 BUILD Hi Team I just thought I would post a photo of the planks now that they are dry, you will see how they are shaped ready to glue on top of the ply parts Regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Guest (7)
