22 Pages «<19202122>
Stefan's build Options
#401 Posted : 26 September 2012 19:23:35
Nice work Stefan Cool
StefanDV
#402 Posted : 27 September 2012 08:25:49
Thanks Hans and Tomick!
Your encouragement is greatly appreciated.
max50
#403 Posted : 27 September 2012 09:06:04
Excellent tiling Stefan, and thanks for the pictures, as it shows me the stages you went through in tiling your hull, from begining to end.
Mal.
Mal.
Built:
Caldercraft - HM Cutter Sherbourne.
StefanDV
#404 Posted : 27 September 2012 10:23:16
Thanks Mal.
After fitting a lot of full tiles on the Port side, I'm now back to the starboard side - fitting the little stealer rows and little 'filler' tiles. Much more time-consuming
I'm now going to completely finish the starboard side.
#405 Posted : 27 September 2012 16:03:36
Hi Steffan.
Looking realy good Mate. How did you find cutting the tiles. just looking for any tips as i have this to come ian BigGrin
StefanDV
#406 Posted : 27 September 2012 17:02:26
Hi Ian,
I did 99% of the cutting with ordinary scissors, just used a knife to trim very small bits off the tiles if needed, or a fine file to make them fit 100%
#407 Posted : 27 September 2012 18:16:04
Hi Stefan, great jobBigGrin will you be putting the false Keel on top of the copper as at 1805?
Regards mike
StefanDV
#408 Posted : 28 September 2012 12:49:24
Thanks Mike.
I'm not quite sure what you are talking about re 1805?? (I'm planning on following the standard build instructions)
#409 Posted : 28 September 2012 13:06:38
Hi steffan.
Thanks for the info Ian Cool
#410 Posted : 28 September 2012 13:17:49
Hi Stefan No problemBigGrin I put a copy of a letter I had received from the curator of the Victory museum in answer to a question I put to him, the tread is in the Victory build discussion topic.BigGrin Regards Mike
StefanDV
#411 Posted : 01 October 2012 09:00:43
Thanks Mike, I saw it - don't know how one would do that it this scale, so I'm just cracking on with the tiles.
All the tiles on the starboard side have now been fitted:
And the portside bow is also complete:
I'm leaving the tiling of the bottom of the keel till last.
Jesus-Belzheim
#412 Posted : 03 October 2012 13:42:11
Looking great Stefan ThumpUp
Can`t wait to start myself BigGrin
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
#413 Posted : 03 October 2012 16:57:34
looking realy impressive steffan keep up the good work Ian Cool
StefanDV
#414 Posted : 05 October 2012 11:12:37
Thanks Peter and Ian!
@Peter: If I know what a time-consuming and long-winded affair the tiling would be, I don't think I would have looked forward to it, but the end result is well worth it.
Tiling continuing on the Port-side stern. (You can see the dis-colourisation of the 2 rows of tiles that was initially laid against the keel)
I should have the hull finished early next week, then to line the top of the keel and the rudder. With clean-up I guess the copper tiling work should be done within the next 2 weeks. :D
#415 Posted : 05 October 2012 13:29:54
Great job there Stefan. I am not tiling mine but yours is reaaly looking good. Quick question, what is causing the discoloring, will it not eventually polish out?
StefanDV
#416 Posted : 06 October 2012 12:59:27
Thanks Hans!
Not sure what is causing it, but I'm waiting until I've completed all the tiling and then give it a clean and a once-off polish. Then I'll leave the tiles to age/discolour naturally.
z8000783
#417 Posted : 06 October 2012 13:02:42
Groups: Unapproved
Nice Stefan and just a bit behind you and following your lead. Mine too as discoloured so interested in what you do to remove it. White spirit cleans up the tiles nicely after gluing but it doesn't touch this stuff.
In the end though, happy for it go go that colour as it look natural but I guess a coat of polish is required if you don't.
John
Jesus-Belzheim
#418 Posted : 07 October 2012 11:07:02
Great job Stefan, and you`r almost ready ThumpUp
And I am not looking forword for the work
It`s the result i`m looking forword for BigGrin
Kind regards
Peter BigGrin
#419 Posted : 07 October 2012 11:32:35
your doing a cracking job stefan,keep it up.
StefanDV
#420 Posted : 09 October 2012 10:43:08
Thanks lads,
some more progress over the weekend up to last night:
Tiling of the port-side stern complete!
Now only the bottom of the keel and the rudder to go!
This page was generated in 0.207 seconds.
