32 Pages «<1213141516>»
#261 Posted : 26 September 2012 21:20:44
BigGrin NP m8 same happens to me at timesCool
saintsman123
#262 Posted : 26 September 2012 22:07:12
now all you need to do is get a huge magnifyer and put all the rivet and screw marks around each porthole, then make them all open and close.
BigGrinBigGrin BigGrin
good work andy
Come on you Jimmies
mark 2
#263 Posted : 27 September 2012 08:05:20
good work andy
Blink BlinkLOL LOL Cool .
Best regards.
#264 Posted : 27 September 2012 17:01:17
BigGrin Hi Saintsman you forgot about getting everest in to do the double glazingLOL LOL Blink Flapper LOL Cool
saintsman123
#265 Posted : 27 September 2012 20:16:44
go for safestyleuk
you konw you buy one you get one free.BigGrin BigGrin BigGrin
b###y advert drives me madCursing
Come on you Jimmies
Smuggler
#266 Posted : 27 September 2012 20:29:35
Looking excellent.....makes me slightly apprehensive about my porthole adventure coming up LOL
I smile because i have NO IDEA whats going on :)
#267 Posted : 27 September 2012 21:00:03
BigGrin Hi Smuggler
theres no reason to be aprehensive m8,if you use 40mm wide masking tape to transfere the portholes like i did.Just line the masking tape up with the top of the hull for the lower[hull] portholes and the top of the hangars for the upper ones.Your 1st portholes will take a lot of time as you make sure its aligned but after as you gain confidence they get easyer and faster GL with yours
#268 Posted : 27 September 2012 21:59:02
i have now finished drilling all the holes for the port side portholes,i have added some to the hull and have some more to add from the plans i have on the hangars[i will add these later].Just the starboard side to do now,as ussual all comments and questions are welcome
harty
#269 Posted : 28 September 2012 01:23:56
She is starting to get that impressive look about her with the superstructure going on Andy. Looking goodCool
Yutaro HONMA
#270 Posted : 28 September 2012 01:47:48
Hi Andy!Laugh
Your voyage seems very satisfactory.BigGrin I'm waiting for your next sending.
Best Regards,
Yutaro
#271 Posted : 28 September 2012 22:58:43
BigGrin Thanks Harty and Yaturo for your kind wordsCool
#272 Posted : 29 September 2012 14:06:42
I have now finished adding all the lower hull portholes[pwewBlink ],i again used 40mm masking tape as described before to transfere them.As ussual all comments and questions are welcome
#273 Posted : 29 September 2012 14:13:39
I have started to add the Deguasing cables to the hull but ran out of the plastic stripCursing LOL so il need to obtain more to finish this off,just a few pics of progress so far.All comments/questions are welcome
Yutaro HONMA
#274 Posted : 29 September 2012 15:55:24
Hi Andy!
Thank you for your help in the Smuggler's topic.
By the way, I have to point the location of the cables. I wrote about it in the #25 post of the "Look before -" topic. I hope you to refer to the post.
Best Regards,
Yutaro
#275 Posted : 29 September 2012 18:29:45
BigGrin Thanks for the reminder Yaturo,i did have that in mind when i was placing the cables but forgotCrying to refer to your mines the offending cables have now been removed.
Thanks again
Yutaro HONMA
#276 Posted : 30 September 2012 06:00:18
You are welcome, AndyBigGrin
I'll post residual mines as early as I can.Cool
Best Regards,
Yutaro
#277 Posted : 30 September 2012 11:25:07
The upper hangar floors are now painted up and placed in position,just a few pics to show this although there may be some adjustments to be made to the forward deck as Yaturo has pointed out.As always all comments/questions are welcome
saintsman123
#278 Posted : 30 September 2012 11:30:45
looking good andy.
i finally started my build, i've got the keel and ribs on, but thats all for the moment i can't start planking as i used some of the wood supplied on a different model and am waiting for cmb to get more stock.
Come on you Jimmies
#279 Posted : 30 September 2012 11:52:26
Nice to hear you have started,just one thing to look out for on the planking.This is the rear step for the armour belts that are added later,the step here is almost non existant[unlike the bow step which is quite large] so you have two choices either cut and fit to obtain the step here or just plank straight across like i did then when it came to fitting the armour belt here i just measured and carved/cut back to get the corect profile to fit.I personaly found it easyer to plank straight across and fettle it to fit, but its your choice,hope this helps
Yutaro HONMA
#280 Posted : 30 September 2012 12:59:46
Hi Saintsman!
If you start planking of the hull, I recommend you to read #4 post of my diary, "A renewed building diary in English" just once.
DeGOSTINI Japan's step told us to use water for warping planks to adjust them to the shape of the hull. I think such a method is not proper.
Best Regards,
Yutaro.
This page was generated in 0.219 seconds.
