ISSUE 4 BUILD Hi Team the object of this weeks build is to assemble 2 Ribs and to fit 2 x part 12 to the Bow former. I am concentrating on fitting the Balsa infills to the Bow and fairing that part (It is easier when it is not fitted to the rest of the ship )so it is part finished. This is what we received this week:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 4 BUILD And the parts we received ( cut from the fret ):- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 4 BUILD I cleaned off the ash and assembled the ribs 13 and 15, I used my board with the plastic fitted to glue all the parts with PVA, and when the glue was dry I placed the ribs in my tile sandwich  :- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 4 BUILD Next I fitted the 2 x parts to the Bow former, and fitted pieces of Balsa between parts 11 and 12 on both sides and also on the end of part 12 both sides:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 4 BUILD Now I began to shape the Balsa with a large file and sand paper block:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 4 BUILD Near the end now, I use my preffered filler to fill in any undulations prior to Fairing the piece, which I do when it is dry:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 4 BUILD Well Team thats it for this session, thank you for looking in, as usual questions and comments are welcome. I leave you as usual with the parts sanded and finished for now. Kind Regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Nice work Mike, hope with your detailed instructions I can get as good a result... thanks for the pics....
Hi mike. I must say that i too am following your build  as you and Mr T are the masters of ship building and a lot can be learnt from you both. Best regards. Mark
Joined: 14/12/2010 Posts: 142 Points: 425 Location: Grantham
The balsa work is looking good there Mike, I have just received Parts 4 & 5 so I'll be having a fun weekend doing my first ever balsa work.
Craig
Gandale wrote:Nice work Mike, hope with your detailed instructions I can get as good a result... thanks for the pics.... Thank you GD  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Blackspear wrote:The balsa work is looking good there Mike, I have just received Parts 4 & 5 so I'll be having a fun weekend doing my first ever balsa work.
Craig Hi Craig thank you for the comments  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
mark 2 wrote:Hi mike. I must say that i too am following your build  as you and Mr T are the masters of ship building and a lot can be learnt from you both. Best regards. Mark Hi Mark thank you for the compliment, but I am not a master, Mr T has probably forgotten more than I know, about model making, plus there are other members far more qualified than me. But I appreciate your sentiments. Just as an aside Mark the way I am constucting the build is my interpretation please be aware while following what I do, that changes could be made by Deag that may affect what I am doing, and could affect your build. just giving you the heads up.But I will help you through should they arise. Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 29/03/2010 Posts: 190 Points: 512 Location: Lytham UK
Hi Mike.. I am following your balsa fill with interest, I might have the confidence to have a go on the Soverein build. Great work again. Best regards, Ian Ian Builds in progress: E-type, HMS Victory, HMS Endeavour, HMS Soverein of the Seas Wish list: Bentley Blower http://forum.model-space...spx?g=posts&m=30439
Hi mike. Looking good mate, see the balsa wood fillets are out again, will you be filletting all the bottom of the hull. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
IAN wrote:Hi Mike..
Best regards, Ian Hi Ian you can do it,I have every confidence in you  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ian smith wrote:Hi mike. Looking good mate, see the balsa wood fillets are out again, will you be filletting all the bottom of the hull. Ian Hi Ian thank you. yes I will all the hull  it makes planking so much easier  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
looking forward to seeing more of your build diary and modifications Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
ian smith wrote:looking forward to seeing more of your build diary and modifications Ian. Hi Ian thank you for that  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 02/09/2012 Posts: 81 Points: 252 Location: Kingston upon Hull
Nice Start Mike like it  . As you know I'm building the Victory at the moment would you recommend putting Balsa in her bow and stern? It's my 1st wooden ship build and it must help a lot with curving the planking... Cheers Chris Builds in progress: DeAgostini HMS VictoryDeAgostini McLaren MP4-23 " If it looks right then it is right "
