16 Pages <1234>»
Jonny's Sovereign Options
#21 Posted : 28 September 2012 18:08:05
Hi Jonny Great job this week some good tips for the new membersBigGrin Regards Mike
mark 2
#22 Posted : 28 September 2012 18:22:02
Hi Jonny.
Great tip with the sanding sticks BigGrin i will have to make some.
Thanks and best regards.
claret
#23 Posted : 08 October 2012 13:11:19
Hi Jonny,
Sanding sticks!, brilliant but simple, will be knocking a couple of these up.
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
#24 Posted : 08 October 2012 14:03:27
Hi Jonny,
Look's like this build will be a good,I can see that you are enjoying this build by your great presentation.Photo's are spot on great stuff Jonny.
Regards Trev.
#25 Posted : 11 December 2012 14:56:06
Hi Johnny, nice to see you back on the build again... looking good...BigGrin BigGrin
#26 Posted : 11 December 2012 15:10:31
I soon took on the task of gluing balsa infill's into the bow section, then left the bow section for a few days to dry.
Then I turned my attention to frames 26 and 27?
That's all from me for a few days...I have some 1" x 1" x 1" blocks to cut before I start adding the frames. I showed where I had filled the bow in with balsa wood, but that is as far as I will go, as I have decided not to use balsa along the length of the false keel, but only where needed? Take care shipmates and catch yer later.
WinkThumpUp
jonny7england attached the following image(s):
#27 Posted : 11 December 2012 15:31:33
Beautiful build there Jonny. Great tip with the sanding sticks works like dream. I used some old 6mm mdf strips of varing sizes and they work well. Keep it up.
Gaz
#28 Posted : 11 December 2012 17:18:03
Looking good Jonny. Keep up the good start and the pics rolling inBigGrin
Gareth
der Gohfelder
#29 Posted : 11 December 2012 19:59:09
A nice start of a new project, go on this way!
Regards, Bernd
#30 Posted : 25 April 2013 20:20:38
Hi there shipmates...Its been literally ages since I last posted anything on my Sovereign build, I have been collecting all the issues and that's about all!! Now that I am just getting back into modelling...Its a case of catch up! I have been following most of the Sovereign builds on here and all very, very impressive, and covering so many interesting tips too! So. I'm going to continue my build posting just the basic pictures..leaving the build tips to those more knowledgeable than I! I have been concentrating on the false keel and ribs and knowing that most of you had long done and dusted this part so far? I thought that I best show what I have done these past few days...Not much but I'm slowly getting back into the rhythm of things...
Blink Blink
#31 Posted : 25 April 2013 20:49:13
Hi Jonny, great to see you back on the SOTS build, been missing your updates... Cool .. Looking good there, look forward to seeing your progress.... BigGrin BigGrin
#32 Posted : 29 April 2013 09:34:16
As usual and expected of you, some good work done there Jonny, well done. Glad to see you are back in full swing.
#33 Posted : 29 April 2013 09:57:33
BigGrin Nice to see you back love the work . Rgd Martyn ThumpUp
#34 Posted : 30 April 2013 16:17:02
And so, the build continues again and I will try to make regular reports as I go along? When many of us were at this stage with our Victory builds, we were all talking about having an in between build while we awaited the Victory parts to come out? Strange that the Victory has become the in between build and the Sovereign takes Centre stage???
#35 Posted : 30 April 2013 16:26:36
Think those gremlins know to keep clear of your work Johnny, they know you are unbeatable.... LOL LOL .. Looking good and coming along very nicely.... BigGrin BigGrin
Best regards
#36 Posted : 03 September 2013 15:29:37
Afternoon shipmates....I'm Baaaack!! (said he in a deep Schwarzenegger tone of voice) He he he. Not exactly been posting as much of late, (my appologies) but I have been observing many of the splendid builds that have been shown on this illustrious forum..I kind of like being well behind everybody else with my builds, I can plot my way around any problems that have been raised by various members? I have been fiddling around with my builds. both Vic and Sov and here is an update in pictures of my sots..not much advancement on my last post but getting there..lol.
#37 Posted : 03 September 2013 16:10:28
Hi Jonny,
Good to hear from you,your build is coming on a treat looking good,you say you like to be behind on most builds but your Victory build is in front of mine,so I need to get a move on.
All the best
Trev.
#38 Posted : 03 September 2013 16:52:17
Thanks Trev...much appreciated...BigGrin
Marcel
#39 Posted : 03 September 2013 17:10:56
BigGrin
Looks neat
I had a loose fit on rib 13a an 13b. This is a factory fault and needs to be exhange. I discovered it too late.
You can also use extra planks (Scrap plywood) to glue over the rib joints. If you cut it to the rib profile, it adds to the seating of the planks, espescially where you had to share half of the rib for joint planking. Something I wished I had done when I started my build.
Happy sailing
Marcel
Sovereign of the Seas
Marcel
#40 Posted : 03 September 2013 17:15:11
I noticed you are using solid pine for your keel jig. Pine distort over time leaving you with mis alignment of parts.Glare Rather use superwood, its worth the trip to the shop.Laugh
16 Pages <1234>»
This page was generated in 1.275 seconds.
