S.O.T.S DISPLAY CASE HELP Options
davie
#1 Posted : 30 September 2012 00:01:49
BigGrin
hi all I am new to this but I am enjoying the build and I love looking at all your progress on the model you have all helped me a lot but I have a problem my kitten keeps trying to eat my model so I need to build myself a display case to protect it I was thinking about what size to build it so the complete ship will fit in when finnished what about 1200mm long X 1000mm high and 500 wide do you think this will be right I did try to lose the cat but it keeps coming back
(as does the wife lol)
thank you for reading this.
All the best dave
court orchard
#2 Posted : 30 September 2012 07:42:35
Hi,
You're definitely going to need a case for the finished model, because these things are almost impossible to clean once they get dusty, which they will of course. I'm speaking from experience, you should see the sorry state of my Albatros. I'm currently having a case made for my Endeavour. The recommended dimensions are 50mm longer and wider than the finished model and 100mm higher, the finished model dims are given in issue 1, on the poster I think. The thought of a cat amongst the rigging would be worse than pigeons.
Sillvestra
#3 Posted : 30 September 2012 10:27:59
This is a very good question and ideally should be moved to the SotS general build forum rather than the build diaries forum.
Wold you send Mr T a request to move it so it is more easily visible to members who don't look at the diary forum topic list... BigGrin
Current Builds:
- HMS Sovereign of the Seas
Planning on Building:
- Scratch built HMS Victory full detail interior (I know what's inside even if you can't see it BigGrin)
Completed Builds:
#4 Posted : 30 September 2012 12:35:44
animals at play,a shudder runs down my spine,my two cats used to have the run of the house,NOT NO MORE,they wrecked two of my ships,no only having a good chew,but knocking them of a shelf 6 foot off the ground,the ship I could live with,but having to wash the walls down afterwards,I did not like and sombo didn't like the shade of red either.so they are banned from the shipyard,and cry all day outside the door,and plead to be let loose again ,NO WAY.if you have animals please make sure you lock 'em up somewhere away from the beloved model.Glare Angry
davie
#5 Posted : 30 September 2012 14:47:23
court orchard wrote:
Hi,
thank you
for youre reply I will start build it at once thanks again dave
davie
#6 Posted : 30 September 2012 14:48:26
thanks for youre help I will start building it now thanks again dave
This page was generated in 1.065 seconds.
