Wood For Assembly Jig? Options
extinctionjet
#1 Posted : 01 October 2012 04:50:15
Hi, I have just started the Sov, and im looking to buy some appropriate wood to construct it with, im just having a hard time finding it, can you advise me where to buy such wood for base board and plywood It appears hard finding the wood, i could not find any such related posts either... thanks.
sam
#2 Posted : 01 October 2012 06:39:35
BigGrin Hi Jet
try your local B and Q or simular or a cheeper way is to visit your local wood yard or joiners yard for off cuts.Hope this helps
Aldo
#3 Posted : 01 October 2012 08:53:38
From the previous replies it needs to be at least 8" wide and 30" long and 10mm thick. If Im wrong Im sure someone will put you right. BigGrin
#4 Posted : 01 October 2012 11:56:56
hi aldo,15mm. thick is best,b & q. I found best,it had all the materials required,and they will cut the wood if necessary.12"(30cm.) the best all round size is 1mtr. x 30mm.wide and 15-20mm thick.with 6" (10.5cm.)brackets.
court orchard
#5 Posted : 01 October 2012 12:10:17
Sorry Karl, don't you mean a width of 30cm not mm.
Sillvestra
#6 Posted : 01 October 2012 14:12:47
I picked up a pine shelf from wickes for approx £8 which was ideal size for the jig base. For brackets, I am using corner reinforcements which are approx £4 for 4 at b&q. Plywood came from b&q also. The only problem there is that they do 6mm thickness and not 5mm... Having the large sheet cut into 3 smaller ones was definitely a plus BigGrin
I''ll be starting a build diary soon as I now have a clear work space and will include pictures of my jig at the start of it BigGrin
Current Builds:
- HMS Sovereign of the Seas
Planning on Building:
- Scratch built HMS Victory full detail interior (I know what's inside even if you can't see it BigGrin)
Completed Builds:
#7 Posted : 01 October 2012 21:25:27
I have also struggled to get suitable wood. Don't drive and live in Swindon so a double problem.
Resorted to the Internet and got my ply from w hobby ltd
http://hobby.uk.com/cata...d+panel&x=0&y=0
Part number P12 was the ply I ordered as its 4mm thick. Panels are really flat and clean so happy with my purchase.
My shelf (ordered 2) were delivered from wickes at no more cost than a return taxi ride.
http://m.wickes.co.uk/mt.../165068?un_jtt_redirect
Hope this might help
Kind regards
Tony
W Hobby catalogue available in WH Smiths and has some very good items in it
Aldo
#8 Posted : 02 October 2012 09:18:49
So 100cm X 30cm and 15mm thick is this correct ? If so I'll try and get a new piece today.
court orchard
#9 Posted : 02 October 2012 10:24:46
That should be fine, the important thing is that it is totally flat.
extinctionjet
#10 Posted : 06 October 2012 04:49:13
Awesome! but for the brackets, doesnt it say 3 slightly larger than 3?
So what brackets would do?!
Hector
#11 Posted : 09 October 2012 11:08:06
For my 5mm ply i went to the local scrap yard and got lots for free from a van interior lining,also found some on a bonfire pile in a bed base but the rain got there first,salvaged my brackets from same pile reclaimed from a wardrobe.
Theres lots of useful bits around for free,wifes nail files are great for getting in the tight spots along with her tweezers,all my files are kept in a cleaned bean can,take-away food containers/coffee jars etc for storage
Tell me the truth,I shall not offend nor be offended
Trotsky
#12 Posted : 09 October 2012 14:44:49
Recycling stuff is a great idea... when you start looking around for stuff to use the list is endless ....well done Hector any other suggestions folks?
H.M.S Victory
H.M.S Victory X Section
D-51
court orchard
#13 Posted : 09 October 2012 15:30:47
Wife's tweezers and nail files free? There will be a cost to that when she finds outLOL
I'm finding the little plastic cannon packets perfect for dispensing small amounts of glue & paint.
It's amazing what some people throw away, if you keep your eyes open.
Sillvestra
#14 Posted : 09 October 2012 16:36:31
I'm a car mechanic by trade. My tool box at work has been raided of duplicate tools to fuel my growing SotS build tool collection BigGrin
Current Builds:
Completed Builds:
Hector
#15 Posted : 12 October 2012 11:21:34
She was fine with the tweezers and files,it was the built-in vanity table i made her and completed just in time to use as my build space that really upset herLOLLOL
Question:said space is built-in to the alcove aside the chimney breast so is walled in on 3 sides,measures 1240mm x 380mm so its gonna be snug and i cant work 360deg around the model,is this going to be workable as i progress?
court orchard
#16 Posted : 12 October 2012 12:20:14
Hi, You are going to need to turn the model frequently when planking or rigging for example. I use a rotating platter, it came with a cheese set from a cheap cook shop. This is because you need to do some of the building in a balanced way to avoid too much force all on one side.
catman275
#17 Posted : 12 October 2012 12:39:47
Tools?,
I have a bag of heavy rubber bands courtesy of the postmen who generally drop them during their rounds.
Peter
completed..... Endeavour Longboat, San Francisco 2, Virginia 1819
building Royal Caroline
This page was generated in 1.959 seconds.
