rope coils Options
Mo
#1 Posted : 01 October 2012 22:42:01
Can anyone run through the actual procedure of making the rope coils,
Cheers
MoBlink
Mo
saintsman123
#2 Posted : 01 October 2012 23:28:54
magpie has something aout this somewhere, i thought it was on his surprise build.
i use double sided tape which i stick to a flat surface, then just carefully coil the thread round. once i've made the coil big enough i brush on some diluted pva and leave it to dry. once dry you can pull the coil off.
however i am sure there are numerous, and better ways to do it and the method is shown here: https://modelshipworld.c...1310-making-rope-coils/
Come on you Jimmies
This page was generated in 0.167 seconds.
