Gold Paint, Gold Leafing or Gold Electroplating Options
SandyM
#1 Posted : 01 October 2012 22:56:55
Gilding work on the Sovereign Of the Seas as we all known is extensive and my first impulse was to Gold Leaf throughout but on refection this maybe making a rod for my own back.
Having done leaf work in the past I found that it is not the easiest thing to do on small intricate parts even if a minutely thin leaf is used. The thinner the gold the easier it is to push through when tapping down and you tend to end up with a patchwork of leaf which then has to be burnished with an agate burnisher to mell the leaf seamlessly together and to polish. The amount of gold wastage is also going to be great so if anyone contemplating leaf work remember and save the waste as a few grams of 24ct gold = a few pints.
I am sorry but the thought of all that gold paint did not appeal to me.
True, paint is easy to apply but even if I used the 24ct paint as used by picture framers it would still look like gold paint.
I thought that was between a rock and a hard place until I saw a colleague at work with a gold plated plastic cover of her phone, which made me wonder if that was the way to get the look that I desired.
I was under the false impression that can only electroplate metal bits and had not considered this as an alterative.
As we don’t yet know if the gingerbread is going to be our own carvings, supplied castings or a mixture of the two I went in search of knowledge to see if this method was possible, how easy it was and lastly how much it would cost.
I found this site www.goldn.co.uk where you can download a free manual on how to brush electroplate anything. Again back to my ignorance I thought an item to be electroplated was submersed in a vat. Not so this system uses small pads, rather like small paint pads, on electrodes which are rubbed over the item.
Depending on what material/process you are plating the current is between 4 and 8 volts
As you would expect this company gives you the free “how to” manual in the hope that you buy there rather expensive plating equipment which for most modelers would not be viable.
I may be braking mad but I wondered if I can utilize a transformer from an old train set, properly checked and marked in increments with a volt meter, a couple of probes from a well known electronics outlet and the brush parts of modelers paint brushes would do the same job and only cost a few bob.
If it comes to it I may have to buy the nibs when I buy the chemicals from the above company. The cost of the chemicals is comparable if not cheaper overall than the Gold leaf with the same overall visual effect.
I think I will give a go and if it works great if not then it will be leafing for me.
Various balsa aircraft both rubber powered and RC
Billing Jyland
Billing Wasa
Billing Dutch Royal Barge (gold medal winner Germany 1975)
Scratch built HMS Victory using HMSO plans hull size 26"
Scratch built Yamato Hull size 8'8"
De Pardo HMS Bounty
Current build Sovereign of the Seas
#2 Posted : 01 October 2012 23:40:30
SandyM
I wish you the very best of luck as this option sounds very complicated and certainly not within my scope to be able to do.
Also done some leafing in the past and fully agree with your comments about small intricate parts being difficult to cover.
My preferred option is going to be an old standby of gold alclad lacquer airbrushed on.
This is applied over their own gloss black bass coat and I feel this will give me the look I am after with making the process over complicated.
Again wish you and the other shipmates all the very best with whatever option you plump for.
Kind regards
Tony
Pietro
#3 Posted : 01 October 2012 23:51:38
Plus 1 on that, the plating looks really interesting but Alclad has got to be the best (easiest!) way....here's their website www.alclad2.com
Pete
court orchard
#4 Posted : 02 October 2012 00:05:01
Hi Sandy,
I have done electroplating at work and also vacuum evaporation of Gold. The problem will be surface preparation which is the tricky part, whilst the plating itself is fairly straightforward, polishing, acid etching, Nickel under layers are all techniques which are needed otherwise you can end up with a very patchy coat. I would imagine suitable surface treatment of the castings could be as difficult or more so than gold leaf. But, I would be interested in your results if you decide to give it a go. I'm going to try leaf just because it's something I've never done before.
Perhaps, Airbrushing as Peter and Tony suggest, is going to be way to go.
We are going to have quite a long time to consider our options before we get to that stage, planking ahoy.
Warthog
#5 Posted : 02 October 2012 00:36:22
Hi..
I wonder if a method I use on my McLaren Build might be of interest?
The small parts can be primmed and then black gloss coated using an air brush or canned from Halfords.. then a coat of clear lacquer. Once this has been done use Alclad2 Gold..
I have no wooden ship parts to show this but i will try it on some wood to see the finished effect and post some pictures later
Spence
SandyM
#6 Posted : 02 October 2012 13:02:46
Hi Guy's,
I think I will give it a go and will post photos of the results if it works out OK. As I have not electroplated before this will be a steep learning curve but that's part of the fun. The preparation of the ground is the key to the finish whatever method is used.
Andy I wish you all best in your leafing if I can help just give a shout.
Can't wait to start.
Sandy
Billing Jyland
Billing Wasa
De Pardo HMS Bounty
#7 Posted : 02 October 2012 16:37:46
Warthog I gonna try your method on some spare cannons(metal)I have ordered the alclad and will also put up some pics when I've tried it.I bought the high gloss black and the gold,also the airbrush cleaner as I've not used cellulose paint in my airbrush.
#8 Posted : 02 October 2012 16:55:21
Karl
I hope you are pleased with the results as I have been when using this product.
It's totally different to enamel paint for instance in that it's pre-thinned and the process is to build the finish up in several light coats.
I used it on the metalwork of the caldercraft Chatham yacht and was very impressed (would post some pics if I knew how).
Although the metal work is painted the kit is far from finished. It was a practice piece and got rather dis-hearted as it did not turn out that well.
Look forward to seeing your results.
Kind regards
Tony
Warthog
#9 Posted : 02 October 2012 22:10:07
I can imagine it should turn out pretty well Karl.. I was also thinking that once the gloss black and lacquer has been applied then it can be left like that and once the parts need a coat of gold then the areas could be masked off with a template of sorts.. I am still refuring to the Surprise and all the gold around the ship btw BigGrin
As for the guns, there are so many different types of finishes from Alclad that even the Cannons would benefit from it..
Be nice to see some results soon
Spence
#10 Posted : 03 October 2012 14:44:55
paint arrived this morning,so without further ado,heres the pics,comments commanded.would really like to know what you think of the finish,I think it has def possibilities.
seams will have to be removed,as the paint is ready thinned,it does not go far,I recon it will take 10 pots of paint,to do the sots decorations.
Warthog
#11 Posted : 03 October 2012 19:47:25
Hi Karl... looks good but a question... What setting to you have on your airbrush compressor? I have mine set to 20 psi and I have only used 1 and a half pots of Chrome on my McLaren... I do very light coats and build it up rather than one heavy coat which will drain the stuff like a emptying bath!!! lol It's all in the fingers as they say!!
Spence
#12 Posted : 03 October 2012 23:17:45
you could very well be right,my compressor is also running at 20 psi. but think my airbrush is opened up too much,when I get more cannons I'll start with it fairly closed,and work my way from there.
Hector
#13 Posted : 06 October 2012 13:14:26
Hi guys,does anyone have pics of gold leaf used on models?
Tell me the truth,I shall not offend nor be offended
This page was generated in 0.517 seconds.
