29 Pages «<2425262728>»
karls new victory build Options
#501 Posted : 02 October 2012 12:38:22
a bit of all sorts this,the 4 boats,three painted and 1 stained.-
petpole
#502 Posted : 02 October 2012 20:48:13
Love the figures you painted, i see the one in the second row is listening to his i-pod LOL , some very good painting there.
Keep up the good work.
BigGrin BigGrin BigGrin BigGrin
#503 Posted : 21 December 2012 23:22:16
Blink Blink Mk.2 Victory started.will post pics tomorrow.Blink Blink
#504 Posted : 22 December 2012 11:53:32
as I'm having an open side,I am furnishings the lower gun deck with gratings,columns,and decking.so a great deal of research and planning is required. I've started by fitting the decking in scale size planks which will be visible through the opening.none of the ribs or deck are glued yet.
#505 Posted : 22 December 2012 11:55:27
all comments welcome.and will endeavor to answer any questions if possible.
#506 Posted : 01 January 2013 15:01:45
added the columns where they are going to be seen,also added the beam knees on the opposite side to the opening.placed a hatch in middle which will also be seen from the opening.painted the far gun reinforcement beam white.
#507 Posted : 01 January 2013 15:03:23
#508 Posted : 01 January 2013 16:07:52
Bameraam
#509 Posted : 01 January 2013 16:27:15
Nicely done grating there, Karl!
#510 Posted : 01 January 2013 16:34:11
thanks berdt, the columns were nearer scale to the real one's(I think)and the hatch grating and companionway with it boards covering for bad weather are interesting.have yet to fix companionway posts and handrails.
hudsonrobert49
#511 Posted : 03 January 2013 06:59:32
Nice work looks Good karl
Rob
Bridlington.
#512 Posted : 03 January 2013 09:34:45
Nice work on the extras Karl Cool
IAN
#513 Posted : 03 January 2013 10:48:48
Hi Karl..
Mark 2 Victory is looking good, will be very interested in seeing what you do with the open secton on the side, as i have been thinking of fill this in.
best regards,
Ian
Ian
Wish list: Bentley Blower
#514 Posted : 03 January 2013 11:37:05
thanks you all for the kind comments,the open area will be hinged,so it can be closed or open,the door part will have fully fitted canons and gun crew.
Bameraam
#515 Posted : 03 January 2013 18:44:37
Wow - thats one hell of a good idea!
#516 Posted : 08 January 2013 01:22:51
Hi Karl.
Pillars look great. Look forward to seeing your idea for cut away section.
Ian Cool
#517 Posted : 08 January 2013 14:18:53
thanks Ian,I'm waiting for the lighting l.e.d.'s I've ordered yellow and will incorporate them into the reinforcement beams,and those on the other side of the opening will be disguised as canons,well that's the idea,hope it works,terminating the led's will be done by two brass wires mounted on top of the reinforced beams,which will go all around the decks.will keep you all posted when the lights arrive.
#518 Posted : 08 January 2013 20:13:27
Look forward to seeing the results Karl, Ian BigGrin
#519 Posted : 10 February 2013 10:58:39
started on the beveling of the ribs,in this pic is the before and after.
continuing on with the l.e.d's.pics later.
#520 Posted : 10 February 2013 18:22:19
This page was generated in 0.189 seconds.
