14 Pages «<23456>»
sandnesspeats Options
saintsman123
#61 Posted : 21 September 2012 23:40:13
looks like some stealers/droppers are needed. there is some info in the mags.
no doubt you have full width planks in the centre and you have tapered right down at bow and stern ends.
instead of making lengths that go all the way to the stern you will need to stop at a rib two or three before the stern.
once it all lines up again you can the taper some planks to fit from whichever rib you have chosen to the stern.
i doubt if any of that really makes any sense, the magazines do tell you how to make droppers and stealers, so maybe read them again.
Come on you Jimmies
sandnesspeats
#62 Posted : 21 September 2012 23:49:31
Hi, I do understand what you are saying,it is just that there is a curve at the stern and I am finding it hard to get the curve out, if i measure it it will just follow the curve.Should have seen this earlier doh!!!Blushing
Thanks for your input,very helpful.BigGrin
sandnesspeats
#63 Posted : 02 October 2012 21:17:23
!!FINALLY!!Flapper Flapper Flapper
Just finished planking the hull, I must admit it was very thought provoking concerning ways to fit the planks at the last stages. Here are some photos of the last stages, it was not exactly straight but managed to get round it by little pieces at a time in some cases.
Now for the sandingCool Cool.
sandnesspeats attached the following image(s):
#64 Posted : 02 October 2012 21:33:07
sandnesspeats I'm amazed that you got that far without tapering the stern planks,and very ingenious way of finishing it.well done and give yourself a pat on the back.Cool
sandnesspeats
#65 Posted : 02 October 2012 21:37:27
Thanks Karl, I think it was all the confidence you all gave me to carry on.BigGrin BigGrin
saintsman123
#66 Posted : 02 October 2012 22:43:36
i see the curve now, don't worry mine was similar, in fact i seem to get a curve on a few of my other builds, but not on others.Confused
the great thing is you have finished the hull, well done.BigGrin
now for the good bit, get the sandpaper out and get sanding, you will be amazed at how good the whole thing looks once it is sanded.
Come on you Jimmies
sandnesspeats
#67 Posted : 02 October 2012 23:18:56
Yeah thanks for help and advice. Yep sanding here i come
BigGrin BigGrin BigGrin
z8000783
#68 Posted : 03 October 2012 06:55:17
Groups: Unapproved
Nice job and good enough to stain if you want to. have you thought about the finish yet?
John
#69 Posted : 03 October 2012 07:48:49
Hi SP well done for finishing the HullBigGrin Good stuff Regards Mike
sandnesspeats
#70 Posted : 03 October 2012 09:25:57
Thanks Mike & john, I am happy with the result,thought i would never get there mind .I am not sure about the finish yet though.
I have bought the paints but I could try staining and if that looks iffy then I will paint.
thanks for all your confidenceBigGrin BigGrin BigGrin
z8000783
#71 Posted : 03 October 2012 09:28:04
Groups: Unapproved
Don't forget the tiles. Mine is starting to look good (not because of me though).
John
#72 Posted : 03 October 2012 09:56:18
Hi sandnesspeats...Great to see you have completed the hull...Looking really good....Keep the pictures coming!!
ThumpUp
sandnesspeats
#73 Posted : 03 October 2012 11:18:48
John
Tiles Confused Confused
sandnesspeats
#74 Posted : 03 October 2012 11:19:56
ThumpUp
Thanks m8. Feeling good at this point
BigGrin
z8000783
#75 Posted : 03 October 2012 11:21:24
Groups: Unapproved
sandnesspeats
#76 Posted : 03 October 2012 11:30:17
z8000783 wrote:
http://forum.model-space.co.uk/default.aspx?g=posts&m=51621#post51621
Something to consider if staining or painting looks iffy.
yours looks great though very impressiveBigGrin .
z8000783
#77 Posted : 03 October 2012 11:33:49
Groups: Unapproved
There are others on here that are brilliant.
You may want to consider it as an alternative rather than a fallback.
John
Jesus-Belzheim
#78 Posted : 03 October 2012 14:06:52
Hi Sandnesspeats
Congratulations for closing the Hull, It looks very good ThumpUp
And now I wish you much fun sanding it BigGrin
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
sandnesspeats
#79 Posted : 03 October 2012 14:38:39
Jesus-Belzheim wrote:
Hi Sandnesspeats
Thanks! just started,I think I will be here for a while Scared BigGrin
sandnesspeats
#80 Posted : 03 October 2012 16:44:08
John
Point Taken thanks.BigGrin BigGrin
14 Pages «<23456>»
