Screws/Screwdriver Options
Steveb
#1 Posted : 04 October 2012 00:00:28
Rank: Newbie
Please please please can someone help me on this. I have just started to build my Mclaren, and i am having the biggest problem in the world being able to get the screws to fit, mainly down to the screwdriver issued. I cannot, and repeat CANNOT get the screws to go in, before i find myself rounding the heads off.
I have tried various screwdrivers that i have, but to no avail, i am struggling like mad, and apart from having very sore hands and running out of screws, i am finding this very dis heartening indeed.
Does anybody have any hints/tips that i can try to overcome this problem ??
Oh, and yes i am using the correct screws as per the instructions/diagrams.
Please help someone, as i am suffering !!!
Many many thanx in antisipation.
Steveb. Grimsby.
only1ianuk
#2 Posted : 04 October 2012 01:23:03
The main great tip is to use a bit of vaseline on the screw.
Plus you can buy better screw drivers to fit which are details in one of the really early posts on the forum!
I'm sure its "00" philips type!
Steveb
#3 Posted : 04 October 2012 01:26:42
Rank: Newbie
Thankyou very much for your reply, i will sure give both tips a try.
Thanx again.
only1ianuk
#4 Posted : 04 October 2012 01:27:23
Thanx again.
Heres a topic regarding it as well.
http://forum.model-space....aspx?g=posts&t=2240
Stupot
#5 Posted : 04 October 2012 10:23:45
Hi Steve, I know exactly what you mean.When i first started the model i thought this is going to be a nightmare.The screwdriver they give you is totally hopeless & will chew up the screwheads.You do get a small plastic attachment in one of the early issues that helps alittle but really isn't very good.I would suggest that you definitely buy a quality mini screwdriver set, it will make your whole build so much easier.I'm on issue 76 now & i found pretty early on that before you screw any of the parts together permanently that you should tighten a screw in the hole first, most of the way in, then remove the screw & then join the parts.The screw should go in alot easier.Keep at it, it gets easier once you get going.Stuart.
firefighter
#6 Posted : 04 October 2012 12:26:38
another tip go to cheap shop a buy some hobby craft screw drivers they are a bit longer and easyier to hold when lining the screw up
#7 Posted : 04 October 2012 17:46:53
Be MEGA careful using Vaseline!
It's a petroleum jelly and can easily remove model paint, apart from rotting surrounding plastic after a year or so.
I know this to my cost building a 1/12 Tamiya Lotus 49 many years ago and using vaseline on the wheel shafts.
Around 18 months later a wheel fell off, and inspection showed all 4 shafts had turned to a black vaseline/plastic mush.
A drop of washing up liquid in a saucer, dip the shaft of the screw in it, dab it on tissue to remove excess, and fit the screw.
Simple.
Any overspill of washing up liquid wipes off - no probs.
Roy.
Steveb
#8 Posted : 04 October 2012 23:45:57
Rank: Newbie
WOW.
Well, what can i say.
Apart from a massive THANKYOU to you all for takin the time to reply, and your generous hints and tips.
I'm shopping tomorrow for screwdriver kits, and will post again next week to let you all know how i get on.
Well am i glad i joined the forum.
Thanx so much to you all.
Steve. Grimsby.
#9 Posted : 05 October 2012 00:42:20
BigGrin Hi Steve
Maplins do some good small screw driver sets at a reasonable price and some good sets of needle/riffler files
trekmeister2k
#10 Posted : 05 October 2012 20:52:17
Rank: Amateur Level 1
Hi Steveb another grimberian I see I have bought screwdrivers from Amazon under the brand Wera and they have been perfect for me see the posted link
http://www.amazon.co.uk/...3Awera+118022&ajr=0
Hope this helps too
This page was generated in 0.183 seconds.
