Ger C wrote:Can't wait to see the finished model Thank you Ger  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
arpurchase wrote: Nice work as ussual Mike Hi Andy I appreciate the comment  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Good looking build there Mike. Looks real with weathering. Great job. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Hans wrote:Good looking build there Mike. Looks real with weathering. Great job. Hi Hans, thanks again for your kind comments  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 25/01/2012 Posts: 134 Points: 385 Location: Berwick Upon Tweed
Mike The turrets look great, its going to be a cracking model when you get to the end of issue 150. Keep up the great work Pete Cheers Peter
Current builds: Amati 1:200 Hood; D51 200 Bought and on the waiting list: HMS Endeavour's Longboat, 1:90 San Juan Nepomuceno, Titanic Lifeboat,1:200 Bismarck Strip and Rebuild [b]Built:1:250 Titanic
Virtue86 wrote:Mike
Pete Hi Pete, thank you for your nice comments  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 57 BUILD Hi team this is a seriously time consuming build  you do need some good specticles to see your way round this one The object of the exercise is to build the first of the models Pom Pom Guns This is what we recrived:- Good luck MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 57 BUILD There are approx 30 brass etch parts on a fret approx 2 x 2 inches,and so it is time consuming. I followed the instructions and here is the build, I did make sure all burrs were filed off the parts:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 57 BUILD Thats all for this session, not alot to show for a few hours work  Questions and comments always welcome. I will leave you with a photo of where we are with this issues build finished:- Kind regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hi Mike. Great job on pom pom gun. i bet the boxes on the side were fidley to glue together. look forward to seeing them aged ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
ian smith wrote:Hi Mike. Great job on pom pom gun. i bet the boxes on the side were fidley to glue together. look forward to seeing them aged ian Hi Ian, you are not wrong each magazine has 5 parts and it measures approx 8 x 5 mm. I will look forward to weathering it Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 13/01/2012 Posts: 605 Points: 1,630 Location: Bucks
Hi Moriarty, you are right  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Mike Just as well my eye's work better over a short distance than they do over long distances, this bit looks quite fun. Well done with it, im still second planking the hull in the spare 5 minutes i get now and then. With regard to the sanding sealer you have mentioned in previous posts, i haven't used it before and am unsure of how to apply it. Do you just paint it on in thin layers and sand back? Your build is looking particularly good Cheers Peter Cheers Peter
Joined: 02/09/2012 Posts: 73 Points: 225 Location: York
Coming on very nicely Mike. Cheers Gus Currently Building:
Eaglemoss HMB Endeavour De Agostini Sovereign of the Seas
Virtue86 wrote:Mike
Cheers
Peter Hi Peter, thank you, just paint it on but please make sure your Hull is as smooth as a babies bum, and use it in a well ventilated room, it should ideally be used after you are totally happy with the Hull finish, it will then seal your work the grain will rise, just light sand it again  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Gus W wrote: Coming on very nicely Mike.
Cheers
Gus
Hi Gus thank you  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 20/04/2010 Posts: 545 Points: 1,536 Location: lossiemouth
MWG wrote:ISSUE 57 BUILD Hi team this is a seriously time consuming build  you do need some good specticles to see your way round this one The object of the exercise is to build the first of the models Pom Pom Guns This is what we recrived:- Good luck just a quire did you recive the two fretts for the pompom guns in that issue as i recived one and an other frett looks like the sights for the small antie air craft guns
willie wrote:MWG wrote:ISSUE 57 BUILD Hi team this is a seriously time consuming build  you do need some good specticles to see your way round this one The object of the exercise is to build the first of the models Pom Pom Guns This is what we recrived:- Good luck just a quire did you recive the two fretts for the pompom guns in that issue as i recived one and an other frett looks like the sights for the small antie air craft guns Hi Willie I did  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Hi Mike nice work on the pom poms,some extra detail on the Yam ato like this would have been nice regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Guest (10)
