Wood Stains? Options
extinctionjet
#1 Posted : 06 October 2012 04:58:41
So im wanting to stain the decks, the rails, doors and a majority of the hull what is the best stain to get? and where can i get it from?
I realy cant find anywhere that sells it?!?
court orchard
#2 Posted : 06 October 2012 11:08:50
Any DIY shop, or B&Q, Homebase etc. Or even EBay.
#3 Posted : 06 October 2012 11:47:51
hi extinctionjet, I'm amazed that you haven't found wood stain,maybe you was blinded by the choice in b& Q.???if you take a look at this pic it will give you some Idea of what can be done with woodstain.
the stains used are these,colron american walnut,canadian cedar,dark oak,
the effect of the hull was to look old and used,was achieved by first using dark oak,then sanded back the canadian cedar,american walnut was used on the gunwales.and interior.
extinctionjet
#4 Posted : 08 October 2012 07:17:31
Hi Karl, you say first using the dark oak then sanded back the canadian cedar? can you explain that please? is it 1 coat of cedar, then dark oak then sand down parts of it to reveal the cedar?
Also, what colour would you sugest to stain the Canon bodies? for a old yet detailed look.. :) thanks!
#5 Posted : 08 October 2012 11:19:24
dark oak was used first,then sanded back with 120 wet & dry,then then cedar was applied.as for the cannon trucks,you can just apply dark oak and then rub down to what you think looks right then varnish satin.
extinctionjet
#6 Posted : 10 October 2012 02:20:42
awesome, where is the best place to get it for hobby uses? Best Brands ect?
#7 Posted : 10 October 2012 07:11:25
BigGrin Hi Jet
B&Q or any good do-it-yourself merchant will have a large range of these items in stock
catman275
#8 Posted : 10 October 2012 18:48:26
Hi All,
I haven't posted lately but am always enjoying the banter and questions etc.
Regarding the wood stains has anyone any experience using printer ink?
I have bottles of cyan magenta yellow and black from my refill cartridge days and wonder if they stain/soak in ok and do they take varnish?
Just interested.
cheers Peter
completed..... Endeavour Longboat, San Francisco 2, Virginia 1819
building Royal Caroline
Sillvestra
#9 Posted : 10 October 2012 19:06:13
Your best bet would be to take the spare wood surrounding the parts for issue 4 onwards and do a few tests with the ink/varnish and see what happens. I doubt anyone on the forum has attempted to colour their models in such a way... I might be wrong BigGrin
Please report back with the results of you tests/experiments including any good pictures of the results BigGrin
Current Builds:
- HMS Sovereign of the Seas
Planning on Building:
- Scratch built HMS Victory full detail interior (I know what's inside even if you can't see it BigGrin)
Completed Builds:
#10 Posted : 10 October 2012 19:18:08
oooo Sillvestra,you have put your foot right in it,check mwg endeavour,and zeptraders victory,both have used inks for colouring wood,on my vic build diary you will find I used printer ink for the deadeyes,it pays to look at other build diary's there a world of tips and experience on show,all you have to do is look and it's FREE.Flapper
#11 Posted : 10 October 2012 20:48:40
Hi Catman
the only problem i can see with using printer ink is its not a permament pigment ie it will fade over time if direct sunlight is allowed to shine on the dyed parts,the range of inks by rowney such as used by MWG on his Endeavor build might be a better bet for colour fastness
catman275
#12 Posted : 10 October 2012 22:16:14
Hi Andy,
Interesting to hear that.
I do prefer the natural wood look when building my models.
I have used stain on occasions but at the moment I am building the Royal Caroline and the upper outer hull is blue. I think I need to have the blue to show up the brass fitting to their best.
The inner bulwarks are a red, well I am going to stain them dark oak or even look for a red type veneer strip.
I am am still tossing ideas around in my head while finishing off the first planking, so I am open to all suggestions at this point.
Cheers to all Peter
Sillvestra
#13 Posted : 11 October 2012 00:26:56
Hi Karl, I stand corrected. Always happy to be proved wrong LOL just thought that printer inks may have been a highly unusual choice for most modelers to use BigGrin
Just too many good builds out there in the forum pages and too little time to look at them all... I'm finding so many good ideas that I want to include or modify that my bookmark folder for build ideas is chockablock...
Current Builds:
Completed Builds:
#14 Posted : 11 October 2012 20:41:26
BigGrin Hi Catman
The rowney artist inks come in a plethora of colours and give an opaque finish so the grain of the wood is shown in all its glory,what i would advise is if you use the above to practice on some scrap 1st so a uniform coverage is obtained,i think if you wet the wood 1st it helps with the flow of the ink and cuts down brush marks.Hope this helps
catman275
#15 Posted : 12 October 2012 00:13:32
Thanks Andy,
I will look into that
cheers Peter
This page was generated in 0.545 seconds.
