Joined: 31/08/2011 Posts: 629 Points: 1,963 Location: Plymouth
Tomick wrote:I see the cat is still hanging on in there Nice work Shuey Thank you Mr T! Chris
chrisgo wrote:Hi Chris. That's a really sweet build you have going there. Although I would have a word with Archie as he doesn't seem to be taking it very seriously..:-) Keep up the good work Chris... From.. errr... Chris..:-) Thanks Chris  Got the difficult decals to do in the next two weeks...need peace and quiet then Chris
Hi Chris really nice work  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Thanks Mike! Chris
 Rank: Semi-Pro Level 1   Groups: Registered
my cat needs to grow so i can do a build diary Aidan :D
 Our cat is Huge.....like a panther!!! Chris
aha just a kitten for us ehe aidan Aidan :D
Do you want to build my one for me lol!! I'm a newbie to model building and am struggling quite a bit, can you tell me what the best glue to use is? I have 4 cats 2 of them just sleep and the other 2 are kittens so just annoy me when I'm doing it, can I borrow yours haha
 Hi there! Welcome to this exciting build mate. I would first suggest that you take your time....there is NO rush and you will have a beautiful and HUGE model at the end of your build. The glue I am using is VITALBOND CA Thick Glue that I bought from my local model shop. Many people are using Wilko plastic glue in the GREEN tube, but I find that a bit too runny The important thing is that you use VERY tiny drops on a cocktail stick. If you are having problems with the screws....dip them in a drop of washing up liquid, it works wonders!!! I would also suggest you get a small set of Screwdrivers with a 00 one in there...there are plenty on ebay! The one they supply you with only Hobbits can use Have fun and good luck! Chris
I have been using super glue and it's very strong but doesn't leave a great finish because it spreads quite a lot when you put pressure on it!! I am up to issue 38 I think!! How do you do the decals?
 Rank: Pro Groups: Registered
Joined: 30/06/2012 Posts: 207 Points: 583 Location: Dunfermline, Scotland
Hi mate, Welcome.I was using super glue to start with but i found it left vapour marks whilst drying on nearby surfaces.Asked for advice & was told to try Wilkinson hard plastic glue.Didn't think it would be any better but thought what the hell & gave it a go.Glad i did, it worked a treat.Bonds as quick as super glue but leaves no marks.As for decals they are ptetty easy to use.Put them in warm (not hot) water for around 20 seconds & then slide them onto the surface with something that won't damage them.You'll get around a minute before they start to set, which is enough time to get them in the right place.Start with the small ones first & get confident then try the larger ones.Hope this helps.Stuart
Hi, this post isn't related to this build, but normal model kits you buy from model shops what's the best way to paint them as I've done a couple and the paint doesn't look too great as there's a lot of paintbrush marks left? Any help would be great
Guest (10)
