 Rank: Pro   Groups: Joined: 04/05/2012 Posts: 362 Points: 1,089
Great job there Mike, The Walnut looks very good
Jesus-Belzheim wrote:Great job there Mike, The Walnut looks very good Hi Peter I am glad you like it. the grain looks just like oak, thank you for the comment  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
I've subscribed to the X-Section and one day it may even arrive. When it does I'll be following your build with a keen eye. Love the work with the Walnut (0.5mm??). Gets rid of all those ugly plywood edges. Keep up the excellent posts and work.
Hello Mike, Had a look at your last post,your X section is looking very good I can tell by your craftmanship you are enjoying this build, such a good idea to cover the riders and mast step.I will be working on my x-section this weekend so I will be posting a few more pictures. Kind Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
tf64 wrote:Hello Mike, Had a look at your last post,your X section is looking very good I can tell by your craftmanship you are enjoying this build, such a good idea to cover the riders and mast step.I will be working on my x-section this weekend so I will be posting a few more pictures.
Kind Regards Trev. Hi Trev, Thank you so much for your nice comments  , You are right so far I am loving it. Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
court orchard wrote:I've subscribed to the X-Section and one day it may even arrive. When it does I'll be following your build with a keen eye. Love the work with the Walnut (0.5mm??). Gets rid of all those ugly plywood edges. Keep up the excellent posts and work. Hi Andy, I look forward to welcoming you to the build  the Walnut is actualy 1mm sorry for the wrong info  Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUES 129 AND 130 BUILDS Hi Team, well here we are again as you know I am planking the main beams, the pump well and the mast base to cover the ends of the ply wood. I have also modified the deck limbers, I am using the Anatomy of the ship for my information. All the build in the photos is dry fitted, I do not intend to use adhesive untill I am satisfied that all is well.The insructions in Issue 130 tell you to stick the pump well in place, this to me is a no no because it is difficult to plank the pump well when it is fixed in the confined space, better to plank it outside the hull. Here are photos of the beam being planked:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUES 129 AND 130 BUILDS At this point I stained the sides of the beams with Georgian Medium Oak (Coloron Wood Dye) and thinned it with white spirit to obtain the same colour as the walnut planking I am applying. -- PLEASE NOTE I applied the dye before I planked the beams so that it would not "bleed" onto the planking:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUES 129 AND 130 BUILDS Then I planked the ends of the beams:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUES 129 AND 128 BUILDS I gave the mast base the same treatment, applying the dye to the sides before planking:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUES 129 AND 130 BUILDS Now it is the turn of the pump well to be planked again I am using my 5mm x 1mm walnut planking:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUES 129 AND 130 BUILDS This is what we received in issue 129:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUES 129 AND 130 I decided to plank the stand with my walnut planking, during this process I soaked the planks to form them around the curves, clamping them while wet untill dry but not using adhesive:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUES 129 And 130 BUILDS Well Team thats the end of this session, the modifications I am doing are my preffered build, you do not have to follow me.The pump well has been dyed with the mix I prepared earlier. Questions and comments are welcome I will leave you with photos of where I am upto at the moment. No part has been fixed with adhesive yet. Kind regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hi Mike, Great work very creative good presentation Mike again your work is outstanding thanks for posting to us all. Kind Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
 Nicely done as ussual Mike Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Well done Mike, It looks very good
Brilliant stuff there Mike. Nice and clean as usual. Well done. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
tf64 wrote:Hi Mike, Great work very creative good presentation Mike again your work is outstanding thanks for posting to us all.
Kind Regards Trev. HI Trev thank very much fo the nice comments  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
arpurchase wrote: Nicely done as ussual Mike Thank you Andy  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Guest (9)
