Strake 7's do not seem long enough Options
dbartonjr
#1 Posted : 10 October 2012 17:51:47
Sorry to post here after sending a PM, but I wanted to make sure this issue is resolved. In the instructions I recived for Yamato #6, insruction 94 it says to Position a strake 7 on the starboard side from frames 6 to 12. Strake 7 is only long enough to reach from frame 6 to 11. I looked at the build diary and it said that the strake goes from frame 5 to 13. As you might imagine I am most confused at this point so any help will be greatly appreciated. Thanks,
Dan
Current Builds: Yamato
On the Bench: Akagi, USS Missouri
#2 Posted : 10 October 2012 18:09:31
The distance length does indeed run 5-13, but as you have found, the strip is not long enough to do this, therefore you can only run to the length you have, then add a further short length to make up the shortfall.
prussian.guard
#3 Posted : 10 October 2012 20:09:17
Ditto on that run it as far as you can and make it up with an offcut you have plenty spare so don't worry about running out.
This page was generated in 2.178 seconds.
