40 Pages «<89101112>»
MWG build diary of HMS Sovereign of the Seas Options
#181 Posted : 05 October 2012 09:16:51
Admiral Anti Spiral wrote:
looking good mike, cant wait to see it all put together ^^
Hi Admiral, thank youBigGrin I am looking forward to that time as wellDrool Regards Mike
#182 Posted : 11 October 2012 09:08:15
ISSUE 6 BUILD
Hi Team, this week again not much to do, just assemble 2 ribs.
This is what we received:-
#183 Posted : 11 October 2012 09:11:32
ISSUE 6 BUILD
Then I cut out the parts and removed all the loose ash from the edges:-
#184 Posted : 11 October 2012 09:15:31
ISSUE 6 BUILD
Now using PVA adhesive I fix the parts of ribs 20 and 21 together, using my board lined with plastic, so the ribs do not stick to the board:-
#185 Posted : 11 October 2012 09:21:30
ISSUE 6 BUILD
Well thats all for this week, my balsa has arrived for the hull I can not wait to get started.
As usual questions and comments are welcomeBigGrin
I will leave you with the tile press filling up, at this stage I have placed 3 extra tiles on top to give extra weight, so we keep everything level and ship shapeBlink excuse the pun.
Kind regards
Mike
cptcrash
#186 Posted : 11 October 2012 12:07:35
Hey MWG forgive the newbie question...but what do you use to get the rough shape of the balsa? I've never used balsa before let alone a model like this but would very much like to give it a go.
cheers
#187 Posted : 11 October 2012 14:42:15
Hi CPT, I measure the space between the ribs, transfer it to the balsa wood and cut using a razor saw and or knife, then shape with sandpaper and file.
I will be doing a tutorial of how I carry out the task, on my build diary.
I have already shown how I do the front rib earlier on in my diary
Thank you for a positive question I hope the answer helps youBigGrin Regards Mike
cptcrash
#188 Posted : 11 October 2012 15:36:02
looking forward to the tutorial MWG :) keep up the brilliant work and cant wait to start my build :D oh and don't worry it wont be the last question ><
#189 Posted : 11 October 2012 18:34:27
Your welcomeBigGrin Regards Mike
Jesus-Belzheim
#190 Posted : 11 October 2012 19:33:25
Hi Mike
There is not much to build yet
But you have enough other Builds BigGrin
I have been looking for balsawood for my next Build
And it`s not really cheap OhMyGod
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
#191 Posted : 12 October 2012 09:02:43
Jesus-Belzheim wrote:
Hi Mike
Hi Peter,thats true, we enjoy the calm beore the storm.
You do not have to fill all the rib space use a box construction, you wil see when I startBlink Regards Mike
Sillvestra
#192 Posted : 12 October 2012 13:21:08
Hi Mike, looking at picking up my balsa this weekend. What sizes do you need for the rib spacings?
Current Builds:
- HMS Sovereign of the Seas
Planning on Building:
- Scratch built HMS Victory full detail interior (I know what's inside even if you can't see it BigGrin)
Completed Builds:
#193 Posted : 12 October 2012 21:28:09
Hi Andy you should get away with 1/2inch x 4inch x 36inch 3 to 4 pieces should do itBigGrin I hope that helps. Regards Mike
#194 Posted : 12 October 2012 21:52:16
PART 2 BOW RIB
Hi Team I have finished fitting the Balsa infills in this completed part.
The filler has been applied (3 thin coats )and the sanding and the fairing is complete.( this process is best done before fitting to the false keel)
Questions and comments welcomeBigGrin Kind regards Mike
Here are the photos:-
#195 Posted : 14 October 2012 11:48:47
Hello Mike,
I see you have been very busy with the SOS,you have put in a good start for us all and well done with the Balsa it reminds me of the early days with the Victory,nice work with the sanding Mike watching with interest.
Kind Regards Trev.
#196 Posted : 15 October 2012 12:32:29
tf64 wrote:
Hello Mike,
Kind Regards Trev.
Hi Trev there is a certain deja vu about itBigGrin its a fab buildCool Regards Mike
pabaz
#197 Posted : 15 October 2012 19:24:49
You are doing an amazing job, your build diary is great, getting so many tips, helping me a lot with my own build. Thanks BigGrin
Paul
HMS Sovereign Of The Seas
#198 Posted : 15 October 2012 21:18:34
Thanks PB much appreciatedBigGrin Regards Mike
#199 Posted : 16 October 2012 14:24:14
Well done Mike, excellent work as usual.
#200 Posted : 16 October 2012 20:44:36
Hi Hans thank you tomorrow we start building properBigGrin Regards Mike
Guest (10)
This page was generated in 5.053 seconds.
