14 Pages «<56789>»
sandnesspeats Options
sandnesspeats
#121 Posted : 19 October 2012 13:43:59
Thanks john,will do that.BigGrin
Jesus-Belzheim
#122 Posted : 20 October 2012 16:35:52
Hi Rob
Your Hull is looking good
Just sand off a little more, and the part wil fit BigGrin
But don`t sand through the Hull Wink
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
sandnesspeats
#123 Posted : 20 October 2012 22:25:56
cheers peterBigGrin
What I did do is use a chisel(no hammerLaugh ) because the hull frame was a different shape,somehow the frame was straight in the middle,so I covered the edge of the stem with felt tip pen and moved it up and down to leave a mark on the frame and just chiseled away at the marks until it was a good fit,seemed to work well.BigGrin.
It is all fitted now and now working on the gallery.BigGrin
#124 Posted : 20 October 2012 23:34:35
Hi Rob
As everyone has said its looking very good! Re: your question about stain-varnishing the hull you'll need to be very carefull with that, even dark stain varnishes are still just varnishes! They cover the surface with a transparent film which means if there are any differences in the material ie. wood and filler that difference may well still show through, it might be reduced considerably but it could still be discernable.Crying
I copper tiled my own Victory (the Del Prado 1/100 scale) making my own tiles out of self adhesive 6mm copper tape as sold for slug defence/dolls house internal wireing on ebay and embossing the rivets into the tape. It cost me about a tenner in all to complete my hull, your Vic is about half as long again as mine so you're probably looking at £15-20 using this method. You can see the effect in my own diary, it looks fairly good especially after a few weeks of oxidising to remove the excess shine. It is very important to give the hull a couple coats of gloss or semi-gloss varnish however to give the tape a good surface to bind to.
Best of luck with your buildBigGrin
sandnesspeats
#125 Posted : 21 October 2012 00:07:01
HI Robin,
thanks for commentBigGrin I realize about the stain/varnish etc, but still not sure what to do as yet, I have been thinking to get as much of the filler off as i can then see.Mellow
Your build looks cool,must have taken an absolute age to complete that copper hull you mentioned and it does look nice.Cool Cool
cheers
rob
#126 Posted : 21 October 2012 04:41:23
Hi Rob Coming along wellBigGrin Regards Mike
sandnesspeats
#127 Posted : 21 October 2012 23:32:27
hi mike,
Thanks as I say never thought I would get there.Blink
robBigGrin
sandnesspeats
#128 Posted : 30 October 2012 23:09:54
Hi folks!!
Bit of advice please, on the photo just above the plank it looks as if the plank is too low for the next plank as the next one has to have that sharp curve, do I move the planks to make it level or sand the keelBlink as there is not much.
thanks again for your adviceBigGrin
cheers
rob
The next two is how it looks so far,any tips would be gratefully received.BigGrin BigGrin
sandnesspeats attached the following image(s):
farrabass
#129 Posted : 31 October 2012 12:22:32
I hope that helps with your request.
Steve..
sandnesspeats
#130 Posted : 31 October 2012 14:10:22
Confused Confused
thanks steve but it was the underside I was thinking of.BigGrin BigGrin
Jesus-Belzheim
#131 Posted : 31 October 2012 14:17:31
Hi sandnesspeats
I would just sand it, does this Picture help?
Kind regards
Peter BigGrin
sandnesspeats
#132 Posted : 31 October 2012 16:56:38
BigGrin BigGrin
Hi peter, that is great very clear, thanksCool Cool Cool
rob
hope I get mine as neatBlink Blink
sandnesspeats
#133 Posted : 31 January 2013 23:31:23
Hi folks!!!
Hope everybody had a great xmas and new year,(bit late I knowBlushing )
I have run in to a bit of a dilemma Crying ,I have run out of eye bolts for fitting on to the back of the cannons to feed the ropes through, don`t know how I am shortConfused.I only need four I think as I am issue 50. Will I need more than this later on.I am at the stage where I am fitting the ten cannons(photo).
Any advice would be great.BigGrin BigGrin BigGrin
#134 Posted : 01 February 2013 13:04:57
HI Rob. Good looking build you have there. As far as the eyebolts go, they normaly are issued with each canon with maybe a spare one. Maybe check your issues as they come in. It helps me to keep my blood pressure down in doing so. I have found a few discrepancies along the way which is normally sorted out with a phone call. Good luck.
sandnesspeats
#135 Posted : 01 February 2013 14:16:03
hi hans,
Thanks for the commentBigGrin .
They are a nightmare to pick up sometimes and one or two must have pinged in to the abyss. I have a lot of rings left though,looked everywhere, might have to make some with electric wire or somethingBlink.
thanks again
rob.
ps as you say might come to a phone callBigGrin
#136 Posted : 01 February 2013 18:48:59
Hi Rob
What size are the eyebolts? I've got some 9mm long by 2mm wide at the bolt end. I was going to say you can get them in most good model shops but then I saw your location! Say no more!Blink
If the size is the same drop me your address by PM and I'll send you up a dozen if that would help.
Mine are left overs from Grimsby and Bounty, they're far too big for 1/100 scale Victorys!
sandnesspeats
#137 Posted : 01 February 2013 20:59:21
Hi Robin,
You are absolutely right about the locationLOL LOL.
Sorry to say that the eye bolts are only about 6mm long 0.5mm thick and the eye is 1 mm, I did however find some electrical wire which is about the right thickness so will have to make that do,I know it is copper but what can I do BigGrin,
Thank you for your offer and best wishes
rob
#138 Posted : 01 February 2013 22:09:40
Hi again Rob.
Sorry about the size! I don't think I've ever seen eyebolts in any model shop down that small so scratch build is probably the only avenue. Good luck with that, that's b****y small and fiddly!
Dontshootme
#139 Posted : 02 February 2013 08:56:24
Have you thought of using freshwater fishing hooks,I realise they may be in short supply on the islands but are readily available on ebay etc
sandnesspeats
#140 Posted : 02 February 2013 11:15:22
Plymouth57 wrote:
Hi again Rob.
Hi robin,
You are right about being fiddly,especially trying to put the ring in to the eye bolt at the bulkheadCursing Cursing .
cheers
Guest (12)
14 Pages «<56789>»
This page was generated in 0.218 seconds.
