3 Pages <123
Riggers 1st Wooden Ship Build HMS Victory Options
Riggers
#41 Posted : 21 October 2012 23:55:28
Riggers, your anchor is very impressive indeed, looking forward to see how your build will progress....
Hello Alan glad you like the anchor and thanks for your kind comments look in any time BigGrin
Cheers
Chris
Builds in progress:
DeAgostini HMS Victory
DeAgostini McLaren MP4-23
" If it looks right then it is right "
Riggers
#42 Posted : 22 October 2012 20:49:37
Hello everyone, I have now finished part one of the launch this is how I got on.
Removed the jig from the plywood sheet using a scalpel and attached the two support strips.
Then carefully removed all the remaining parts...
and glued all the frames in place making sure each one was square to the jig.
Modifications: None.
Problems: All slots in the jig had to be widened using a flat file before the frames would properly fit. Be very careful with the frames I broke frame 5 inserting it into its slot and had to do a repair. May be it's just me who's heavy handed! BigGrin
That's it till next time thanks for reading...
Any comments or questions most welcome...
Cheers
Chris
Builds in progress:
Riggers
#43 Posted : 31 October 2012 22:07:06
Hi everyone I've now finished part 2 of the launch this is how I got on.
One thing I found difficult when I first started making my Victory was what tools and materials to use so I thought to assist new builders of the Victory I would from now on include an image of the tools etc that I used with each stage of construction. This is only what I used other people may use different items.
Although I've never done this before fairing the hull was straight forward to help me I kept placing a plank on the launch ribs as I sanded away making sure it touched every rib.
I used a 20mm sanding block with P180 sand paper and a mini flat file.
Laid my FIRST EVER PLANK BigGrin bent the plank to shape with a plank bender then glued it in place using thick super glue. (As mentioned in Mr T's official build diary) The bow end was cut to shape with a scalpel.
I then carried on laying planks until the hull was complete. Brushed the complete hull with wood glue to fill all the plank joints wiping the access off with a damp cloth then finishing off with a light sanding filling any indents and imperfections with super filler mixed with a little wood glue. (The filler on its own seemed far too soft when sanded hence the added wood glue).
For my first attempt at a wooden hull I was well pleased BigGrin
Lastly the double plank around the top of the launch was fitted again with thick super glue and finished off by brushing wood glue around the edge cleaning off the access with a damp cloth.
Here are the tools I used. The plank bender was amazing it was expensive (had to save up for it) but worth every penny I can see it coming in very handy on the planks on the main hull. I have two scalpels each with a different shape blade fitted a No10 and a No10A that way you don't have to keep changing to a different blade should you need to if you only have one scalpel.
The only thing left to do was to cut the launch from the jig with a razor saw and scalpel. Job done for stage two of the launches build.
Enjoyed my first steps into wooden ship building and am looking forward to fitting out the launch.
Cheers
Chris
Builds in progress:
farrabass
#44 Posted : 31 October 2012 22:13:12
Very competent attempt at the launch there Riggers!
You have taken to this hobby like a duck to water, keep it up, a master in the making!!!
Great stuff, all the best, Steve..
DaDokta
#45 Posted : 31 October 2012 23:12:33
Coming along nicely - keep up the good work!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#46 Posted : 31 October 2012 23:19:33
Hi Riggers, Top JobBigGrin Regards MikeCool
#47 Posted : 01 November 2012 09:33:53
Well done Riggers. Looks great keep up the good work.
Jesus-Belzheim
#48 Posted : 03 November 2012 15:01:50
Hi Chris
Your Launch is looking great ThumpUp
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
Riggers
#49 Posted : 05 November 2012 20:52:52
Hello Steve DaDokta Mike Hans & Peter thank you all for your kind comments much appreciated BigGrin
Should have the next stage completed and ready to post this week along with some more tool ideas I missed out in my last post.
Cheers
Chris
Builds in progress:
#50 Posted : 14 November 2012 22:24:26
Hi riggers.
Great job. Keep up the good work. Ian Cool
#51 Posted : 14 November 2012 22:46:17
Hi Riggers, very nice job of the launch hull indeed... look forward to seeing your posts in the future....BigGrin
Riggers
#52 Posted : 17 November 2012 11:31:44
ian smith wrote:
Hi riggers.
Thanks Ian BigGrin
Cheers
Chris
Builds in progress:
Riggers
#53 Posted : 17 November 2012 11:34:10
Hi Alan
Thanks for popping in, glad you like the launch so far, next installment should be along at the end of the weekend BigGrin
Cheers
Chris
Builds in progress:
#54 Posted : 08 December 2012 15:23:26
Hi Riggers, really nice clean workBigGrin Regards Mike
der Gohfelder
#55 Posted : 08 December 2012 16:15:52
Hi Chris!
Nice work, can we see some new photos?
Regards, Bernd
Gauncer
#56 Posted : 13 July 2015 18:49:56
Amazing. Wish you did not stop posting. It would had been cool to see how you work ended up.
-JG
In the workshop: HMS Victory
Finished builds: Providence Whaleboat
Guest (6)
3 Pages <123
This page was generated in 0.940 seconds.
