Captains Quarters mullions Options
Mo
#1 Posted : 22 October 2012 21:39:07
I have been looking ahead at some things, I see there are columns to be fitted between the mullions of the windows of the Captains Quarters, I have tried mine, and the gap is to small to take the metal columns supplied. Has anyone else got this far, or could you check your bits to see if they fit.
Mo
Mo
#2 Posted : 22 October 2012 22:23:56
BigGrin Hi it may be a case of file to fit,but obviously takeing an equal amount from each end ,just guessing here as i havent seen there size/shape perhaps a look at magpie,s build to see what he did is a must i thinkCool
moriarty
#3 Posted : 23 October 2012 11:53:27
Mine all fitted Mo with not too much trouble, just a bit off filing on the side ones too get the angle.
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
Mo
#4 Posted : 23 October 2012 14:17:53
ok Thanks for that, a bit of fileing will be done.
Mo
Mo
This page was generated in 0.336 seconds.
