Hull Plan Options
SandyM
#1 Posted : 28 October 2012 12:35:48
I wonder if Mr T or Admin can provide a view of the completed hull with all frames and decks in place before planking. This would enable me to plan the modifications I need to do to get the effects I am hoping to achieve.
Sandy
Various balsa aircraft both rubber powered and RC
Billing Jyland
Billing Wasa
Billing Dutch Royal Barge (gold medal winner Germany 1975)
Scratch built HMS Victory using HMSO plans hull size 26"
Scratch built Yamato Hull size 8'8"
De Pardo HMS Bounty
Current build Sovereign of the Seas
#2 Posted : 28 October 2012 14:13:30
Afraid I cant give you so far in advance, other than to say that first two decks are in place by 14 and the final frame/gallery framework added at 15, where my build diary will reflect this nearer the time, but in the meantime this image might help...which is where she should be at by around isue 40..
SotS at iss 40.png (381kb) downloaded 285 time(s).
SandyM
#3 Posted : 28 October 2012 15:25:10
Thanks Mr T.
I just wondered if there was a drawing or plan showing the all the ribs without the planking but I see from your photo there going a lot of modifications to add the lower decks. One last thing what timber will used to plank the upper decks.
Sandy
Billing Jyland
Billing Wasa
De Pardo HMS Bounty
#4 Posted : 28 October 2012 15:43:24
I've not seen the deck planking as yet, but as soon as I do I'll let you know
harvardhound
#5 Posted : 28 October 2012 19:06:54
Great to see where we should be by week 40.
Thanks
Paul
Building - Sovereign Of The Seas
SandyM
#6 Posted : 28 October 2012 23:47:51
Thanks a lot Mr T
Sandy
Billing Jyland
Billing Wasa
De Pardo HMS Bounty
NMBROOK
#7 Posted : 31 October 2012 22:03:17
If you google deagostini passion you will find a link of the italian site.In their forum there is a section of build instructions.I cant speak italian but its easy to find.This shows the instructions up to about week 38 which is where there at.The pictures are fairly self explanitory.The bamboo first planking didnt get much praise from what i can make out from the member builds and apparently its a real b****r to sand,i think i for one will invest in lime strips.
court orchard
#8 Posted : 31 October 2012 23:02:47
Interesting thanks, I also noticed that they were having the infamous problem with rib 13, way back in February.
Explains why I haven't come across Bamboo being used before, as it is nice and flexible, but as you say ease of sanding is a key issue too.
This page was generated in 0.770 seconds.
