51 Pages «<23456>»
DaDokta`s Build Options
StefanDV
#61 Posted : 06 July 2012 13:21:19
Very neat! Well done.
Jesus-Belzheim
#62 Posted : 07 July 2012 15:08:20
Hi DaDokta
Your Deck is looking very good ThumpUp
Keep up the good work BigGrin
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
Sietsemk
#63 Posted : 10 July 2012 13:01:48
Your build is looking good, your workplace is very clean!!BigGrin
Built
Albatross, build in 1982 from plans.
Hms Bounty, build in 1987 from plans.
Duyfken,build in 1991 from plans
Oosterland, build in 1998 from plans
In the meantime.
HMS Victory (Deagostini)
2011 Building MFV63 fishing trawler from plans.
HMS Mayflower (Kit)
Wish list
Still planning.
Castos
#64 Posted : 11 July 2012 08:13:01
Nice build and it could soon be in the category of a museum build.
Current Build: HMS Victory
Built: HMS Bounty
Next Build: Sovereign of the Seas Started collecting. Redrawing of plans for Santisima Trinidad for a scratchbuild. Santisima Trinidad - waiting for launch.
DaDokta
#65 Posted : 11 July 2012 08:40:42
Thanks for your nice comments :)
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#66 Posted : 11 July 2012 08:42:52
Hi very nice workBigGrin Regards Mike
DaDokta
#67 Posted : 20 July 2012 14:38:11
The finshed upper gun deck after two coats of varnish:
The upper half of the hull is now fully planked:
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
Jesus-Belzheim
#68 Posted : 21 July 2012 04:19:24
Your Hull is looking good DaDokta ThumpUp
Kind regards
Peter BigGrin
#69 Posted : 24 August 2012 13:34:29
Good looking build you have there. Keep up the good work.
DaDokta
#70 Posted : 27 September 2012 11:49:59
Hi shipmates!
I´ve been busy cutting the upper-deck gun ports and way more so framing all the ports! What a time consuming work!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#71 Posted : 27 September 2012 12:26:15
Hi Doc, you have made great progressBigGrin good stuff, Regards Mike
z8000783
#72 Posted : 02 October 2012 10:07:54
Groups: Unapproved
You may want to put on a second, makes life a little easier when you do the 'last 10'.
Looks great.
John
DaDokta
#73 Posted : 02 October 2012 12:25:43
Thanks for the advice John!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
StefanDV
#74 Posted : 03 October 2012 11:27:23
Excellent advice from John, I put on an additional 2 rows and it certainly made planking the last 10 rows much easier.
DaDokta
#75 Posted : 18 October 2012 20:06:19
I finally finished the hull!!!!!!
Sanding paper - here i come!!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
Riggers
#76 Posted : 19 October 2012 23:25:19
Hello DaDokta, congratulations on completing the hull planking ThumpUp
Cheers
Chris
Builds in progress:
DeAgostini HMS Victory
DeAgostini McLaren MP4-23
" If it looks right then it is right "
Jesus-Belzheim
#77 Posted : 20 October 2012 15:56:44
Congratulations for closing the Hull BigGrin
I wish much fun sanding it Wink
Kind regards
Peter BigGrin
DaDokta
#78 Posted : 29 October 2012 09:40:55
The last days have gone by with filling and sanding.
This being my first experiances with wood modelling, i must say i`m very pleased with the results so far.
Next step will be fitting the keel.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
saintsman123
#79 Posted : 29 October 2012 12:44:05
its amazing how some filler and sanding can produce such a good finish.
great workBigGrin
Come on you Jimmies
DaDokta
#80 Posted : 29 October 2012 14:44:10
Thanks for the nice comments!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
51 Pages «<23456>»
This page was generated in 1.005 seconds.
