162 Pages «<56789>»
#121 Posted : 05 November 2012 21:38:02
Well have now finished the rough sanding and fairing of the hull.... will complete the task with some filler and final fine sanding... Hope I have shaped the stern section correctly, no doubt will find out when we get down to the planking. Will probably start with the filler and fine sand tomorrow. A long task but one well worth doing....
#122 Posted : 05 November 2012 21:40:09
Ger C wrote:
Hi Alan,
She looks great
Thanks Ger C and thanks for looking in...BigGrin
#123 Posted : 07 November 2012 22:16:50
Picked up issue 10 from the newagents today and was hoping to do some work on the old girl tonight but disappointingly, when I inspected the parts found they were quite badly warped, think the last image shows what I found. So without cutting anything from the fret, have now placed the parts in hot water to soak and will then place them in my glass press under weight. Hopefully they will dry and flat enough to carry on working on her this weekend. Here are the parts I received.
#124 Posted : 07 November 2012 22:19:58
The one thing I was able to do this evening was to repair the hole in the balsa infill on one of the forward sections. I did this by following the instructions on MWG's tutorial, post number 300.. Have to say the repair isn't noticeable...
mark 2
#125 Posted : 07 November 2012 22:35:38
Hi Gandale.
Your hull looks great.
Shame about the parts in issue 10.
Best regards.
#126 Posted : 07 November 2012 22:46:00
mark 2 wrote:
Hi Gandale.
Best regards.
Thanks for the nice comment Mark.... it is a pity about the warped parts but we have all had to deal with them at some time or other.... putting it down to the experience of the build.....LOL LOL
court orchard
#127 Posted : 07 November 2012 23:45:45
Build's looking good Alan. As pace setter and pack leader we're relying on you for Heads-up on these problems, I'm relaxing in your and Mikes slipstream at the momentLOL
#128 Posted : 08 November 2012 00:08:26
LOL LOL Thanks for the nice comment Andy....you know what they say about pace setters.... they run out of steam before the end....BigGrin Just thoroughly enjoying the build and trying to learn as much as I can before I tackle the build I really want to do... The Vic.... Will always give a heads up to any problems I encounter.... Watching your build very closely...
court orchard
#129 Posted : 08 November 2012 00:40:00
Know what you mean about the Vic. one day i'll go for the Caldercraft Kit, but it's pushing £800. Crying But the SOTS is quite exciting, it's a fairly untraveled road, every man and his dog has done the Vic, but I think we've got the chance of doing something new here. Must have more water with my Whisky.LOL
#130 Posted : 08 November 2012 00:51:06
Hi Alan your build is excellentBigGrin The Balsa work on the Hull looks very good, a credit to youCool I am really sorry you have had a bad experience with the parts of issue 10.
Kind regards
Mike
#131 Posted : 08 November 2012 19:34:13
Kind regards
Mike
Thanks Mike, am happy I gave your excellent tutorial justice.Cool Cool ... it is a bad experience with the parts in issue 10 but am confident it can be put right before continuing.... had a look at them earlier and it is better but needs more work yet....
#132 Posted : 08 November 2012 19:38:17
Having looked at the pictures of the finished artical I have to say I am not too keen on the white hull.... am thinking of doing the 2nd layer of the lower hull in walnut.... will probably make that decision when I see what Deagostini provide and whether I have the skill necessary to get away with finishing in walnut..... Does anyone else have similar thoughts?????
#133 Posted : 08 November 2012 20:15:12
Hi Alan yes I am keeping my options open on this project till later, you can do it, its not difficultBigGrin Regards Mike
court orchard
#134 Posted : 08 November 2012 20:36:48
Have a look at the Italian forum. They are up to issue 40 or 50. You can get a good idea of where things are going. For example you can see that there's a lot of extra stuff going onto the stern. So it's wise to stay away from any Balsa there. As regards Walnut it's just the same as any other wood in terms of workability.
#135 Posted : 09 November 2012 00:13:55
Thanks Andy and have had a look... not too many images but interesting none the less..... Was thinking of walnut more for the look rather than workability,,, just don't like the white hull, think it looks out of place on a ship such as this..... find it hard to believe hulls were white in those days.....
#136 Posted : 09 November 2012 00:25:12
Have just spent some time fairing the hull of the launch and have to say it is not the easiest thing to do, not because the task is difficult but because the ribs are just so so delicate.... have to take it very slowly and easily or else they will break..... Anybody have easier ways to do it?
court orchard
#137 Posted : 09 November 2012 09:53:24
Hi Alan,
Where's all that Balsa when you need itFlapper LOL LOL
But seriously, what I do when I want to sand away something very delicate, is I use my Dremel with it's flexi-drive and a SiC paper disc. This removes material without putting any force on it. But care is needed obviously, I'm about to do this with my Launch.
#138 Posted : 09 November 2012 15:26:08
I personally keep powertools well away from the delicate work,I'm much to clumsy,I use sandpaper on a piece of planking,several grades,and fair very gently,takes about an hour or so.also have dowel stick with stuck on sandpaper for the curved bits.
claret
#139 Posted : 09 November 2012 19:41:26
Hi Alan,
Looks excellent, the balsa work and fairing is bril!
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
#140 Posted : 09 November 2012 20:26:47
Hi Alan,
Thanks Andy, typical isn't it, balsa is never around when you need it the most....LOL . I too have the Dremel with a felxi-drive but not sure I want to put it anywhere near the build..... will do some practice work on some scrap wood first and see how it goes from there... looking forward to seeing your launch and will be publishing pics of mine real soon....
Guest (17)
162 Pages «<56789>»
This page was generated in 6.796 seconds.
