Tip for issue 7, planking the launch Options
#1 Posted : 10 May 2010 18:05:46
Looking at Tomick's build, you have to be careful not to get glue on parts number 3 (near the bow) as these parts are removed after planking. Give them a good rubbing with candle wax will stop any stray glue accidentally gluing them into the launch. Alternatively, put a small piece of Cellotape over them to stop the glue sticking.
Cheers
snowtiger
#2 Posted : 10 May 2010 23:08:53
Cool tip ...thanks MarkBigGrin
#3 Posted : 10 May 2010 23:16:39
good tip thanks. question if i do get glue on somthing i should not can i get it off?
piot007
#4 Posted : 18 May 2010 07:26:10
lol yeah sounds like me. i'll need an answer to that 1 as well.
Capt Stedders
#5 Posted : 18 May 2010 10:06:10
Cheers
Good advice, although I'd be wary of using candlewax if I intended to paint the model afterward (Paint is reluctant to stick to waxed surfaces and you'll have a hell of a time trying to remove traces of wax from such a fiddly area)
As for the sellotape, this is a safer bet, although you will have to allow for the thickness when contouring the bow.
The best bet is to avoid getting glue on the areas that you shouldn't in the first place.
BigGrin
In the worst case scenario (Eg: you have glued the top of parts 3 to the bow former AND planks to the aforementioned bits) wait until you have removed the planked launch from the jig and using either a Dremel (very carefully) or a combination of EXTREME CARE, knife, and curved rifflers / needle files, remove the offending bits.
The main worry in such circumstances is the very thin planking - one false move and you'll be making nasty holes in your planking, so my suggestion would be to leave a little of the part 3 formers still attached to the hull - slightly messy, but much better than a gaping hole.
Schnellboots on back burner
Tools.
willie
#6 Posted : 18 May 2010 10:14:23
i use candle wax on the corner of my build table about a foot square and clamp parts glued to geather never had problems painting after words
#7 Posted : 18 May 2010 12:05:45
Assuming you're using PVA, it's best to wipe it off with a damp cloth while it's still wet.
Alternatively, a very sharp knife and you should be able to get dried glue off. As others have said, the planking is very thin, so go careful. Dried PVA is slightly rubbery, which is why it doesn't sand well. Sandpaper or a Dremel tool might not work very well. They should be fine (but go careful with the Dremel, they can be a bit brutal) if you're using Alaphatic resin.
Mike Turpin
#8 Posted : 18 May 2010 12:20:00
Just to remind members who are planking their launch, Tomick recommends thick super glue rather than PVA glues for attaching the planking along the ribs.
I am assuming that Super Glue Remover will soften a joint if necessary, what do others think?
Mike T
#9 Posted : 18 May 2010 12:47:19
Superglue Gel works a treat for the Launch planking, you might find PVA tricky to use when it comes to holding what are fragile planks in place, and also because the planking is very thin, too much PVA can warp thin planking as it dries, you could also consider a stringless contact adhesive when applying thin strips.
Son of Bulwark
#10 Posted : 18 May 2010 13:47:30
Hi shipmates! BigGrin
Have you tried cling film instead of cellotape much thinner and fits to the shape better. If the glue sticks to the film it just takes a little rub to remove it!.
ThumpUp
lee.takel
#11 Posted : 18 May 2010 14:51:44
Great tip Son of Bulwark, used cling film to protect parts of Bismarck whilst building her
This page was generated in 0.144 seconds.
