Joined: 30/01/2011 Posts: 865 Points: 2,410 Location: Cambs
if you buy an a/l kit you normally get a couple of wooden pedestals and a baseboard without any holes. all i have done in the past is drill through the base board into the bottom of them and put a screw through. then the keel usually fits straight into the slot, keeping it in place. however those look like metal, and judging by the size of the surprise i don't think they are going to hold very well. if there is sideways movement then the keel could actually rip off. i know these come as part of the kit, but you would be better off using another method, or even make a better stand yourself. sorry i could not have been any real help. Come on you Jimmies
Joined: 25/01/2010 Posts: 459 Points: 1,367 Location: Bridlington
Glad you got it sorted
New Question, Can Anybody help With or Recommend Display Cases. Where to get them etc, I've looked around but no joy Yet. Regards
Rob
Bridlington.
Joined: 20/10/2010 Posts: 511 Points: 1,459 Location: Loughborough
