Joined: 10/10/2012 Posts: 66 Points: 191 Location: UK
Hello again, can anyone recommend what brand of drill and type/composition of drill bits for the 0.5mm and 1.0mm bits. I am not sure mine are strong enough to drill a hole as required by the instructions, steps 11 and 12 drilling into the command post. Thanks for your help. Current Builds: Yamato On the Bench: Akagi, USS Missouri
An auto strike centre punch will help in centering the drill points and prevent the bit from skidding off. You'll also find that bits with a shank are much tougher than the norm.
