How much balsa do I need for a hull infill? Options
RobT
#1 Posted : 18 November 2012 18:47:21
I am interested in infilling the hull to make planking easier. However, I am unsure of the amount and size of balsa I need, the approx cost and the best place to buy from.
I know it's a big question, but can anyone help me out please? Also, are there any tools needed other than general modelling tools?
#2 Posted : 18 November 2012 19:34:00
Lots of info amongst the Sovereign build diaries and in discussion
mark 2
#3 Posted : 18 November 2012 21:35:42
Hi RobT.
On my sos i used 2 off 1/2 inch by 36inch by 4inch wide lengths of balsa and i got them from http://www.cornwallmodelboats.co.uk/acatalog/
But there is also http://balsacabin.webs.com/index.html
http://www.alshobbies.com/
Toolwise knife, plane and sandpaper.
A plane is not essentual but does help.
Best regards.
slowboat
#4 Posted : 20 November 2012 18:41:09
if you can find a local model plane shop they will stock different thickness balsa planks, may even off cuts you can buy.
#5 Posted : 20 November 2012 20:41:26
Hi Rob...In my local modelling shop. they sell balsa wood in bundles of varying thicknesses which they order in from elsewhere? The bundles are only around two quid. I am sure that you would be able to pick something similar from a modelling or craft shop in your area?
Wink ThumpUp
This page was generated in 1.446 seconds.
