162 Pages «<89101112>»
#181 Posted : 19 November 2012 00:37:05
MWG wrote:
BigGrin Alan, your work seems fine to meBigGrin Your decking went down like mine because your measurements when fitting the Balsa fillets were spot on!!!ThumpUp Top Job Regards Mike
Thanks Mike, feels like I am sitting on your shoulder watching eveything you do..... hope the weight of me doesn't get you down too much.....LOL LOL
#182 Posted : 19 November 2012 01:06:56
Hi Alan ,not at all no problemBigGrin Kind regards Mike
#183 Posted : 19 November 2012 23:07:23
Well tonight I managed to finally complete the planking on the ships launch and for a first attempt I am quietly pleased with the outcome.... Tomorrow will give the hull a fine sanding to complete the job unless of course the launch is also double planked....Blink Blink
#184 Posted : 20 November 2012 14:52:31
Completed the fine sanding of the ships launch. Now ready for it's first coat of primer.... Now thinking whether to paint or stain, airing on the side of painting. Will see what the official build diary and mag shows before deciding....BigGrin
#185 Posted : 20 November 2012 16:42:08
Hi Alan a vsry nice jobBigGrin Spot on Regards Mike
#186 Posted : 20 November 2012 18:50:42
Thanks for the nice comment Mike.. Thoroughly enjoyed putting this together...onwards we go eh....BigGrin BigGrin
claret
#187 Posted : 21 November 2012 08:53:17
Hi alan,
The launch is looking awesomeBigGrin
claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
#188 Posted : 21 November 2012 21:41:06
claret wrote:
Hi alan,
claret
Thanks for those kind words Claret and thanks for looking in.....BigGrin
#189 Posted : 22 November 2012 22:23:46
Issue 12 collected from the newsagents and parts shown here were checked for any damage.... none to be seen...
#190 Posted : 22 November 2012 22:33:37
Started work on glueing and pinning the lower deck.... Partially set the pins in place along the rib lines on all sections. Then applied PVA to all the lower deck supports and pinned the decks in place. Having the pins partially set meant the task could be quickly completed before the glue started to set... Everything slotted together very nicely I am happy to say.....
#191 Posted : 22 November 2012 22:56:50
Started fitting the dummy gun support beams. First beam to be fitted was between ribs 13 and 21, ensuring it was cut to size and only covering half the rib on both 13 and 21. Also shaped the lower edge of the beam to sit flush on the deck. Once happy with the dry fit then glued and clamped in place.. Would have liked to pin the beams to the ribs but sadly, used all the pins on pinning the deck down and being a first build I still have to build up supplies and spares....CoolCool
#192 Posted : 22 November 2012 22:59:56
Will continue fitting the gun support beams tomorrow and hopefully make a start on fitting the deck supports for the next deck.... Happy building all.....BigGrin BigGrin
#193 Posted : 24 November 2012 23:03:41
Finally finished fitting the dummy gun support beams. At one stage I thought I had cut the slits too far but thankfully not. Now making a start on the deck supports, have them all cut to size and just about to glue in place..... More tomorrow.....BigGrin BigGrin
#194 Posted : 24 November 2012 23:20:34
That's one nice looking ship coming on there Alan, I think with the amount of detail in this ship you can't beat the painted finish. Best of luck and keep the pics coming!Cool
#195 Posted : 25 November 2012 00:00:11
Thanks Robin, have to agree with you regarding the amount of detail this ship will have.... as there is very little historical information on her decor it does give us a certain amount of freedom as to the finish... The only thing I know for certain is I am not painting the hull white, will either stain or apply walnut veneer... the veneer option is looking favourite..... Thanks for taking the time to look in and comment...Cool Cool
#196 Posted : 25 November 2012 03:13:39
Hi Alan, you should be proud of your build BigGrin It s a credit to you, top job. Kind regards Mike
#197 Posted : 25 November 2012 13:29:48
Thanks Mike, have to admit I do feel an element of pride in how she has came together so far but realise there is still a long way to go and lots to learn.... Thanks for looking in again...Cool Cool
#198 Posted : 25 November 2012 13:34:11
Have now completed fitting the deck support spars across the ribs and glued in place. Feels very flimsey so as an extra precaution am now using 6mm beech dowel to add additional supports.....Mellow Mellow
claret
#199 Posted : 25 November 2012 18:51:41
Hi Alan,
She is looking brilliant.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#200 Posted : 25 November 2012 20:05:49
claret wrote:
Hi Alan,
Claret
Thanks for looking in Claret, appreciate your nice comment... Hope you get yours sorted out soon.....BigGrin
This page was generated in 0.195 seconds.
