40 Pages «<1819202122>»
MWG build diary of HMS Sovereign of the Seas Options
#381 Posted : 23 November 2012 11:06:21
Your usual high standards Mike, excellent work. I too intend to add additional supports for the next deck.. Would rather be safe than sorry....Cool
Thank you Alan for the nice commentsBigGrin fitting the extra supports will helpCool Regards Mike
#382 Posted : 23 November 2012 13:46:49
delboy271155 wrote:
MWG wrote:
ISSUE 12 BUILD
The object this week is to fit the Dummy cannon beams, and deck supports between the ribs, to support the next deck, wether it be another ply deck or deck planks, as yet we do not know.
I followed the instructions, no problems there, but I did add the two enhancements ---- the first was to also pin the beams to the inside of the rib with a pin punch, this gave a much better fix.
The second enhancement was the inclusion of a piece of 1/4inch dowel underneath the deck supports (Placed in the middle) the reason for this? well what ever deck we put on next we are going to apply pressure to the beams, this could result in breakages in the centre of the deck supports, its just an extra precaution:-
Hi Mike
Not up to this point yet but I can see the wisdom in the dowel supports. I would not deem to teach an expert how to suck eggs, but my thought is that if we are fitting the same sort of deck as last time, then may be 3 dowel supports across each cross beam (evenly spaced) may give more pinning points ,or would that be classed as overkill.
Delboy271155
Hi Derek, thank you, you can put as many supports as you wish, but in my opinion one in the middle is enough, till we see the nature of the deck pieceBigGrin Kind regards Mike
#383 Posted : 23 November 2012 22:50:21
Jesus-Belzheim wrote:
Hi Mike
That looks very good ThumpUp
Still waiting for the S.O.S to come out in Germany
And thanks for the answer about the glue BigGrin
Hi Peter Thank you for your commentsBigGrin you are welcome. Regards Mike
#384 Posted : 24 November 2012 03:58:28
ian smith wrote:
Hi mike.
Looking good.like the dowl idea.
Ian. Cool
Thanks Ian, they work wellBigGrin Regards Mike
#385 Posted : 29 November 2012 17:45:25
ISSUE 13 BUILD
Hi Team, this week we received wood and iron ware for the continuation of the launch.
As I have stated before I am building my own launch as an enhancement, which I will continue building later, This is what we received:-
Kind regards MikeBigGrin
pabaz
#386 Posted : 04 December 2012 20:37:32
Hi Mike, watching your build with great interest, learning so much.
Could you tell me what size dowel you used for the mast when you were fitting the deck sections.
Thanks
Paul
HMS Sovereign Of The Seas
#387 Posted : 05 December 2012 10:01:14
Thanks
Hi Paul, Thank you, the size of the dowel is 10mm for the centre mastBigGrin I hope that helps you. Kind regards Mike
#388 Posted : 05 December 2012 10:15:30
Terrific work Mike!! My builds are on hold for a short while..Still keeping an eye on your build diary though..All great stuff mate!!
Wink ThumpUp
#389 Posted : 05 December 2012 11:46:14
Wink ThumpUp
Hi Jonny, thank you very muchBigGrin Kind regards Mike
#390 Posted : 07 December 2012 09:55:11
ISSUE 14 BUILD
Hi Team, well here we are and already over 3months have past (how time flys when you are having fun)
This week we receive the parts for the second deck:-
#391 Posted : 07 December 2012 10:00:27
ISSUE 14 BUILD
I chose to paint all the dummy gun batterns black as my first task, taking care not to get paint all over the place, I used the Dull black that comes in the De Ag paint set:-
#392 Posted : 07 December 2012 10:04:13
ISSUE 14 BUILD
My next task was to cut off the excess dummy gun beams with a razor saw, and sand the cut areas with a ladies nail shaper:-
#393 Posted : 07 December 2012 10:12:19
ISSUE 14 BUILD
Last but by no means least I fitted the deck pieces, starting at the Bow (front)I used water jugs filled with water to give weight to help press the decks to the beams (that is why I fitted supports to the beams in build 13)
The decks slotted in to place with no adjustments, by just following the instructions:-
#394 Posted : 07 December 2012 10:16:47
ISSUE 14 BUILD
Thats all for this session Team. As usual questions and comments welcomeBigGrin I will leave you with a photo of how she looks after Build 14 Kind regards Mike
#395 Posted : 07 December 2012 21:49:01
Really looking good Mike, taking shape very nicely now.... Thanks for sharing....Cool
der Gohfelder
#396 Posted : 07 December 2012 22:17:05
Your build looks very good, respect!
Regards, Bernd
#397 Posted : 07 December 2012 23:07:42
Thanks Alan, Kind regards Mike
#398 Posted : 08 December 2012 00:04:29
Regards, Bernd
Thank you Bernd for your nice commentsBigGrin Kind regards Mike
NMBROOK
#399 Posted : 10 December 2012 01:37:50
Hi mike,I was browsing your build log and am afraid to say that i dont think you should have fitted the balsa infills in the stem.I am sorry to be the bearer of bad news but I am almost certain the lower framework is exposed when the model is complete,if you go on deagostini passion,the italian site.Their build log is at week 40ish and shows the stem fitted and painted.
Regards Nigel
#400 Posted : 10 December 2012 02:26:50
Hi Nigel as I have said to other members making the same observation, you are correct in what you sayBigGrin However the balsa infills have kept my stem straight and true.
I will need to cut out some balsa from the stem but I do feel this is a small price to pay for the benefits of keeping the stem straightLove Thank you for your commentsCool Kind regards MikeWink
Guest (8)
This page was generated in 9.649 seconds.
