25 Pages «<23456>»
Claret's SOTS Build Diary Options
claret
#61 Posted : 25 November 2012 23:16:53
Hi,
With everything going together much better, I proceeded onwards and fitted the beams to the inside edges of the ribs on the bottom deck. they fitted into place and were held with clamps until the glue set.
I also added the deck supports for the next deck, but decided to use dowelling to support the beams, slightly over kill, but adds more strengthen.
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
claret
#62 Posted : 25 November 2012 23:19:54
Hi,
Also managed to finish planking the launch, not bad for a first attempt and I hope that painting it will hide some of the imperfections.
Thats it for now.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#63 Posted : 25 November 2012 23:40:30
brilliant claret,now your really moving.well done.
#64 Posted : 25 November 2012 23:46:39
Wow Claret, you have been busy this weekend and the results on display are fab, so pleased you resolved the problems and were able to put it right..... Continue with the good work and keep posting those pics..... Again, very well done....BigGrin BigGrin
claret
#65 Posted : 26 November 2012 09:08:05
Thanks Karl and Alan for your kind comments.
ClaretBigGrin
Also working on:
SOTS.
finished:
007 Iconic DB5.
#66 Posted : 26 November 2012 10:43:05
Hi Claret, well done, top jobBigGrin glad everything is back on track, kind regards Mike
claret
#67 Posted : 26 November 2012 11:52:51
Hi mike,
Thanks for the kind words.
I will start balsa infilling now everything is in the correct positions, but will do it slowly over the next few weeks.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#68 Posted : 29 November 2012 08:46:19
Hi Dominic,
Thanks for the words of encouragement.
Yes, surprising how sturdy the model is. cutting the balsa out was messy but straight forward. the wood being softer than the ribs helped.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#69 Posted : 29 November 2012 08:55:47
Hi,
Had a play with the ship's launch last night, removing it from the jig. Again, surprising how sturdy the boat is when assembled.
I used a razor saw, and cut well away from the launch planking.
I then snipped of the excess jibs above the top plank line, but not to close to the planking.
One or two did break at the planking, but nothing serious.
The ribs were then sanded sown as explained in the assembly guide.
To finish, I stuck the last part on after a little sanding to get it into shape. a little filler used to fill in a couple of gaps that I will file down tonight.
Overall, i am pleased with the result.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#70 Posted : 29 November 2012 08:59:40
Hi,
i have also started to balsa infill again, but decided not to box each section in, but rather put balsa on each side of the rib formers and bottom deck. Only the bottom deck progress showing in the picture.
This should give me more surface area to glue the planking to and also help in fairing the hull into shape.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#71 Posted : 29 November 2012 21:58:43
Claret, looks like your problems were a thing of the past....very well done, you are storming ahead now, keep it up.....BigGrin
claret
#72 Posted : 29 November 2012 23:10:55
Hi Alan,
Thanks. I am much happier now with the build.
I know where I went wrong and only have myself to blame. Steep learning curve!
Claret.
Also working on:
SOTS.
finished:
007 Iconic DB5.
#73 Posted : 29 November 2012 23:19:37
claret wrote:
Hi Alan,
Claret.
Couldn't agree more but it's the challenge of conquering the learning curve that keeps us from giving up...... Supporting you all the way Claret..... Best regards
#74 Posted : 30 November 2012 21:46:15
claret wrote:
Hi Alan,
Claret.
Hi Claret glad you are now back on the straight and narrowBigGrin Kind regards Mike
claret
#75 Posted : 30 November 2012 23:32:35
Hi Mike,
Many thanks.
Busy weekend, but hope to get a bit more done and load photos!
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#76 Posted : 02 December 2012 17:41:32
Hi,
Added balsa infills to the rib formers and sanded down to the contours of the rib formers.
Also primed and painted the dummy cannon recesses.
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#77 Posted : 02 December 2012 17:44:11
Hi,
I have glued the launch's anchor together, primed and painted black and brown. Not very clear from the picture.
Also working on:
SOTS.
finished:
007 Iconic DB5.
der Gohfelder
#78 Posted : 02 December 2012 18:33:46
Nice weekend-work, well done!
Regards, Bernd
#79 Posted : 02 December 2012 21:45:13
Nice work Claret, no holding you back now eh.... keep it up...
claret
#80 Posted : 08 December 2012 01:08:28
Hi Bernd & Alan,
Thanks for your comments.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
25 Pages «<23456>»
This page was generated in 1.072 seconds.
