Hi all, This is my first ever build of this kind so taking things slowly. I have infilled with balsa from bow to stern(as per mikes instructions - bless him), what I need to find out is this: does the fairing on ribs 5,6 and 7 have to be quite heavy as my bow looks very bulbous at the moment. Regards Delboy Derek COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
delboy271155 wrote: Hi all, This is my first ever build of this kind so taking things slowly. I have infilled with balsa from bow to stern(as per mikes instructions - bless him), what I need to find out is this: does the fairing on ribs 5,6 and 7 have to be quite heavy as my bow looks very bulbous at the moment. Regards Delboy Derek Derek, any chance you can post an image.... it would help builders to advise you with accuracy..... Regards Alan
Gandale wrote:[quote=delboy271155] Hi all, This is my first ever build of this kind so taking things slowly. I have infilled with balsa from bow to stern(as per mikes instructions - bless him), what I need to find out is this: does the fairing on ribs 5,6 and 7 have to be quite heavy as my bow looks very bulbous at the moment. Regards Delboy Derek Derek, any chance you can post an image.... it would help builders to advise you with accuracy..... Regards Alan[/quote Thanks Alan will try to post pics (technofobe here) Have not shaped ribs 5,6 and7 totally as not sure how far to go. COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Delboy, you are almost there...don't take any more of the front. You are taking it down to give you a smooth flowing surface across all of the ribs... take a look at my build post 117 and you should see what I am referring to.... the bow is quite bulbous as you will see... If you are still unsure then wait for Mr T's official build and the mag instructions to explain how to complete the task of fairing the hull....
Hope this helps.
Delboy, if you resize your images to 600x450 pixels then when uploaded they will show on your post....
Gandale wrote:Delboy, you are almost there...don't take any more of the front. You are taking it down to give you a smooth flowing surface across all of the ribs... take a look at my build post 117 and you should see what I am referring to.... the bow is quite bulbous as you will see... If you are still unsure then wait for Mr T's official build and the mag instructions to explain how to complete the task of fairing the hull....
Hope this helps.
Alan Many thanks I now see exactly what you say. I will now have to take a computer course to work out this picture sizing bit. Regards Delboy COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
