Plank Bender Options
The Borg
#1 Posted : 29 November 2012 01:06:11
Rank: Newbie
Hi All,
Now I know this may seem a stupid question but can someone please tell me HOW to use a Plank Bender? Having got one in my freebie tool kit it just seems a complete and utter mystery to me Confused
Any help would be really appreciated.
Ger C
#2 Posted : 29 November 2012 01:18:05
From my (limited) experience the blade should be used to cut into the inside of the curve, the greater the curve required then the closer these cuts should be,
I am sure that others may be able to provide more detail!
But be careful not ti cut through the plank,
Hope this helps
Ger C
#3 Posted : 29 November 2012 01:26:37
Which ship are you building?
catman275
#4 Posted : 29 November 2012 02:52:37
Hi Borg,
I guess you are a Star Trek fan like my son.
I am not far from you in Waltham Forest
This link below within this site will give you a lot of info including use of a plank bender.
Cheers Peter
http://forum.model-space...t.aspx?g=posts&t=552
completed..... Endeavour Longboat, San Francisco 2, Virginia 1819
building Royal Caroline
#5 Posted : 29 November 2012 09:26:55
Hi Borg,
Plank bending pliers or plank nippers as they are also known, put notches into the plank surface which allows the plank to bend, (the notched side is the inside surface of the plank).
The closer you place the notches to each other, then the tighter the curve the plank will bend around, and if you place the benders at an angle to the wood (not 90 degrees which is used normally), you can also introduce a twist in the plank. Use a plank offcut to practice on or check which way you need to angle pliers to get the bend/twist you want.
If recall rightly, the blade of your tool kit bender is reversible, in that one side of the blade has a blunt edge used for bending, and opposite side has a sharp plank cutting edge.
Dont over squeeze the handles of the tool, which may cause the plank to snap breal the tool handles. For hardwoos planks, soaking, steaming or an electric bender is better suited.
