14 Pages «<34567>»
Yet another Victory by Bernd Options
Bernd
#81 Posted : 01 December 2012 23:27:16
der Gohfelder wrote:
Nice datails, thanks a lot!
Regards, (also) Bernd
You're welcome, (also) Bernd!
#82 Posted : 02 December 2012 22:46:17
Bernd, I can only describe your build as simply stunning and insprirational.... loving following your progress....BigGrin BigGrin
#83 Posted : 03 December 2012 14:01:21
Wow, my hat off to you what a terific peice of work love the scroll work what a great ideaDrool
#84 Posted : 04 December 2012 09:24:13
Exceptional clean build there Bernd. Wonderful attention to detail. Well done. Will be following with great interest. Love your enhancements
Bernd
#85 Posted : 07 December 2012 00:33:55
Hi, shipmates,
thank you for your friendly comments.
Presently, I am shaping masts and yards and attaching blocks etc., closely following the instructions - so there is nothing to show in photos that hasn't been shown before.
But meanwhile, I can tell you what I did a few months ago. Let me continue where I left off.
Right behind the pin rail on the quarterdeck is the opening for the companionway.
Here I inserted a custom built ladder with 9 steps (more comfortable for a scaled-down Admiral Nelson)
The pillars are carved from a 2x2 mm woodstrip. (I do not particularly like the bulky form of the pillars provided with the kit.)
Moreover, I added nailheads and the nets as decorative elements.
Finally, I built the handrails from brass wire
Kind regards,
Bernd
#86 Posted : 07 December 2012 01:54:06
Hi Bernd, A-MAZ-INGDrool Kind regards Mike
#87 Posted : 07 December 2012 08:51:13
Well done Bernd, I can't wait to see the end result Cool
saintsman123
#88 Posted : 07 December 2012 12:53:28
yet more fantasic work bernd. sehr gutBigGrin Love
Come on you Jimmies
Bernd
#89 Posted : 07 December 2012 22:40:21
Having completed the quarterdeck companionway, I added some details on the fore deck:
the three gratings and the galley chimney
My gratings have been sanded down for a rounded shape.
As I plan to use smaller belaye pins (thanks to Mike), I felt no need to replace the pin rail posts with higher ones. There should be enough room for tying knots.
The chimney is turned brass, cut into two halves at 45 degrees and glued together to form a right angle. I thought the one provided with the kit was to slim.
I know, the chimney should be totally black, but I thought the thin brass stripes would look nice.
der Gohfelder
#90 Posted : 07 December 2012 22:43:39
Nice ideas and perfect built! Congratulation!
Regards, Bernd
Bernd
#91 Posted : 07 December 2012 22:50:38
For some reason, I had issue no 58 twice, so I had enough parts to build a second skylight like the one on the poop deck, but what should I do with it?
It might seem strange, but I cut it into halves to make it smaller:
and added a bottom which I painted black on the upper side
Next I placed some wood-strips into the quarter deck opening
Then I applied plenty of PVA glue to the bottom of the "semi-skylight" and let it glide down the woodstrips.
When the glue was still wet it was easy to shift it into the right position.
All this would have been much easier, had I thought of it earlier...
Actually, it is quite dark there, but I cut a hole into the deck under the first grating, so a little light can shine through.
Therefore you can see it even if there is no direct light:
What I tried to model is the galley skylight.
On the following image of the battery deck it can be seen right in front of the gratings and behind the chimney:
#92 Posted : 08 December 2012 00:22:04
Ouch.... my jaw hurts from hitting the deck in awe of your build..... love it....Drool
Bernd
#93 Posted : 09 December 2012 22:08:59
An amusing image, Alan, thank you!
Greetings from Austria,
Bernd
Bernd
#94 Posted : 09 December 2012 22:11:26
My next project were the hand rails next to the quarter deck opening. I first tried an all-metal solution
But I didn't like the style of the handrails of the stairs - it's kind of a modern design which doesn't really belong to the Victory.
In the end I decided to replace the brass handrails by ropes. This is how it looks now:
mark 2
#95 Posted : 09 December 2012 22:47:22
Hi Bernd.
The rope looks far better.
You was right to use the rope.
Fantastic as allways.
Best regards.
Gaz
#96 Posted : 09 December 2012 23:28:54
Wow a fantastic build you have there. Keep up the good work. Look forward to seeing more of your work.
Gareth
#97 Posted : 10 December 2012 08:48:42
Brilliant, brilliant build you have there Bernd. I particularly like your enhancements. It makes her unique to you. Well done.
Bernd
#98 Posted : 19 December 2012 00:39:09
Dear all, thank you for the nice comments!
Here are some more details for the quarter deck:
The guns are routine work by now
I used 2mm blocks for the rigging
I had to make the guns aim slightly downwards, otherwise the barrels would have been a little too high in relation to the gun ports
There was not enough room in front of the cabin walls, so I omitted the blocks there (they can't be seen anyway). I will place a fake rope there later to simulate the rigging.
Bernd
Bernd
#99 Posted : 19 December 2012 00:40:12
Next, I built the ladders to the poop deck and added the details for the inner bulwarks
I already told you about the binnacle (page 1 of my diary)
Finally, an overview of the bulwark, for comparison with the original
Bernd
#100 Posted : 19 December 2012 00:41:54
Further details for the poop deck ladders: I replaced the brass stanchions by pillars carved from boxwood
and added a wooden handrail
For the other side of the ladder I tried to insert eyebolts
But I wasn't quite happy with the big eyes of the eyebolts. Here is my present version of the ladders, I think I can live with it
Guest (14)
14 Pages «<34567>»
This page was generated in 0.177 seconds.
