2 Pages 12>
Launch Options
stujue
#1 Posted : 06 December 2012 19:18:44
Can anyone help. I've made a mess of the planking on the launch. I've ordered another issue for another go. Any advice on best glue to use, or how to hold in position while glue sets would be very greatly appreciated
Cheers
Stu
Cheers Stu
denissimo
#2 Posted : 06 December 2012 19:46:21
Superglue
Model boats built so far:-
Billings Cutty Sark
Scratch built twin IC RC Vosper MTB.
Scratch built rc electric hybrid.
Scratch built rc IC hydrofoil (ran happily on snow as well as water!)
Plus numerous numerous RC planes.
Under construction
Sovereign of the Seas!
1200:1 HMS Victory (by Mantua)
The Battleship Yamato (seriously considering building as an RC model)
der Gohfelder
#3 Posted : 06 December 2012 19:52:58
Agree, I´ve made all plankings at the launch of my Victory with superglue.
Regards, Bernd
denissimo
#4 Posted : 06 December 2012 19:55:02
Using superglue means you dont need to use clamps.
Just hold the plank in place for a few seconds until the glue goes off and there you have it.
Just dont attach your fingers as well LOL
Billings Cutty Sark
Under construction
der Gohfelder
#5 Posted : 06 December 2012 19:57:25
That´s the reason, why we have ten of them BigGrin
Regards, Bernd
stujue
#6 Posted : 06 December 2012 20:42:42
thanks for replies, sounds like a plan. superglue it is.
Cheers Stu
denissimo
#7 Posted : 06 December 2012 20:44:45
Regards, Bernd
I never realised that was the reason Bernd Laugh
You learn something new from this group every dayLOL
Cheers
Den
Billings Cutty Sark
Under construction
luigione
#8 Posted : 07 December 2012 00:13:43
Which is the best type of superglue? I'm having some difficulty in getting the planks to stay in place at the bow end as there is hardly anything for the plank to attach to.
RobT
#9 Posted : 07 December 2012 00:16:53
I used this one:
http://www.diy.com/nav/d...10548887?skuId=11039419
The gel is better as it doesn't run off, just sits there as a mini blob.
I know what you mean though about nothing to hang on to. Planking that launch would test the patience of a saint.
luigione
#10 Posted : 07 December 2012 00:36:56
Yep, it is a pain in the butt, I've decided to add a little bit of wood either side of the bow frame in order for the planks to have something more to hold onto, it shouldn't be noticable as it will be hidden by the other bits we'll be adding later.
Aldo
#11 Posted : 13 December 2012 14:37:14
Well the air was certainly blue in my house for the last 1-2 hours this has driven me absolutely mad I have just put some on so I can fill the gaps with filler Cursing Cursing Cursing. The super glue was just about as much use than a chocolate fire guard. My fingers are covered in glue Cursing Cursing Cursing
Admiral Anti Spiral
#12 Posted : 13 December 2012 15:45:17
Make sure the planks are flexible, using hot water. also i found some super glues are very liquidy, a slightly thick super glue should do the trick with a small dab of it, good luck!
Processing - Progressing
Previous builds: HMS Victory
andyp
#13 Posted : 13 December 2012 15:57:03
Try putting the gel on with a cocktail stick.That way you can put it where you need it and it's not so messy.A slightly long fingernail will hold the planks in place and is easier to get off if it sticksCursing
court orchard
#14 Posted : 13 December 2012 16:17:37
That's a good tip, I also use a cocktail stick or a metal probe and then count to 30 slowly before I let go. CA or Super glue uses the slight moisture in the wood to set, so if the wood is extremely dry then it sometimes doesn't set or sets very slowly. A very slight dampening can help or breathing on it also helps (with the moisture in your breath). Be careful about actually wetting the planks, as too much moisture will cause it to cure incorrectly, it won't hold the joint and you'll get a cloudy white mess.
saintsman123
#15 Posted : 13 December 2012 19:30:26
having stuck my fingers to various items such as planks, tweezers, each other, i found something to help prevent it happening.
there is a product on the baking shelves of supermarkets which comes in a spray, its used for spraying on baking tins so the cakes don't stick, but i find just a little spray on my fingers prevents them getting stuck. it is not perfect but has certainly reduced the frequency of me having to pull my fingers apart.
Come on you Jimmies
#16 Posted : 13 December 2012 21:45:37
Hi Saintsman123!
That's a good idea about that spray. Just had a thought though, have you tried painting any of the wood that you've handled with the glue proof fingers yet? I'm just wondering if the wood absorbs any of the spray and whether it would affect the finish of water based paints?
Best Wishes
marls
#17 Posted : 16 December 2012 19:31:19
[quote=stujue]Can anyone help. I've made a mess of the planking on the launch. I've ordered another issue for another go. Any advice on best glue to use, or how to hold in position while glue sets would be very greatly appreciated
Cheers
only problem with supper glue is it makes the wood less plyable. As pva makes the wood softer
#18 Posted : 16 December 2012 19:45:48
If you apply superglue gel to the frames rather than the plank, you should find its okay, and if you start at one end and gradually work your way along you should not need clamps or bands.
Mike Smith
#19 Posted : 20 December 2012 15:44:27
Rank: Beginner Level 3
There is another option which I used when planking the launch.......hold it in place with an elastic band. I used wood glue and then placed the elastic band over the plank. It will run the full length and wrap around the bow and the stern. It does work...........fiddly but it works.
Mike
slowboat
#20 Posted : 20 December 2012 20:23:25
Manaaged so far with the first planks on the launch by wetting them under the hot water tap gradually bending to just a bit more than the required curve and then holding them on a balsa plank with drawing pins until dry, an hour in the airing cupboard is enough. Easy to put on then with super glue. See how we get on with the rest.
2 Pages 12>
This page was generated in 0.279 seconds.
