Glad to be of help Wilfy and yes those etch plates do look a bit thick as you say, so might be worth the effort even though very fiddly!!
I think the 'buffable' metal paints look brill when done properly? Even though I have started to use mostly acrylics on my models now, I still have most of the old Humbrol 'Rub'n'Buff' type enamel metallic paints, which I like to use for simulating metal work on small areas, the 'Polished Steel' one is excellent!! With the Red Oxide/Hull Red engine bay I reckon if you add a few simulated oil stains and general dust and grubbiness to the area, it will look about right mate?
I'll look forward to seeing how you get on Wilfy?
Kev
 Hi Wilfy nice work getting round the engine problem and the etch well thats the problem with it at times its either too thick or to thin, gussets for example, depending on where its going.I see Kev sorted out the engine bay colour aswell something to remember for the future regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 06/06/2010 Posts: 566 Points: 1,657 Location: UK
Hi, Thanks for your comments Andy & Kev. It's great to have some encouragement. Have given the engine a coat of Mr Metal Colour Dark Iron. Will put pics up when dried off fully. The only trouble with this paint is that it seems to remain buffable forever. Needs a good coat or two of varnish to seal it in, else you transfer it everywhere! I've got a couple of thing to do to the chassis before I fit the engine. The first being removing the tow bracket (?) at the front & replacing it with etch. Marked by the red arrow in pic. Thanks Wilfy Wilfy the Sea Dog attached the following image(s):
Bracket safely removed. Wilfy the Sea Dog attached the following image(s):
Nice job Wilfy, it doesn't look like the bracket was ever there in the first place!!
Always happy to encourage the military/aviation builds on MS as I think we need a bit more of it on here and if it helps to bring more in, then I'm happy to praise those that already build stuff like this. Well done mate and keep up the good work!!
Looking forward to seeing the etch bracket replacement.
Kev
Joined: 06/08/2011 Posts: 480 Points: 1,421 Location: Galway
Nice work, Am following your build with interest
Thanks again for all your comments, interest & encouragement. Have buffed up the engine now, using a combination of cotton buds, a spectacle cleaning cloth & a medium stiff paint brush. The engine itself was a bit fiddly & by some miracle I only knocked two parts off! Do have to be a bit careful with the buffing as you can buff all the way through. Ready now for sealing off & picking out some detail parts. Thanks again. Wilfy Wilfy the Sea Dog attached the following image(s):
Very nice work Wilfy and the etch certainly does add an extra sharpness to the engine now that it is painted, should look even better with a nice oil wash to pick out the detail.
Well done and keep up the good work.
Kev
Hi Wilfy. Your build is going great and the engine looks fantastic. Keep up the great work  . Best regards. Mark
Thanks for all the comments guys.
Haven't made much progress over the last month.
Have done a few bits on the chasis, some pics to follow.
Wilfy
Here's the chasis assembly with a coat of hull red. Also a little shot of some of the detail. Wilfy the Sea Dog attached the following image(s):
Steering rack assembly, has some nice detail & not too fiddly to put together. Wilfy the Sea Dog attached the following image(s):
Have started to fit the internal components on the chasis. Some great detail here, sadly it will all be hidden once complete. I know it's there though. wilfy Wilfy the Sea Dog attached the following image(s):
Have started to assemble the running gear now, so more updates shortly hopefully!
Thanks for taking the time to look & all comments welcome.
Wilfy
Hi Wilfy. The detail does look very good on this manufacturer  . As you said its a shame its coverd up. Coming along great now wilfy  . Best regards. Mark
Looks a nicely detailed kit Wilfy
Joined: 17/11/2012 Posts: 863 Points: 2,608 Location: Gohfeld (Germany)
Nice work until now, go on this way! Regards, Bernd
 Very nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 27/08/2012 Posts: 104 Points: 312 Location: Brome Lake Quebec
Wilfy This is looking like a great build. I'm thinking about trying a half track next so I'm interested to see your progress and to see a different manufacturer from the regular bunch.
John
Engin looks stunning interested to see how this comes together “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
