Decal advice and clear coating questions (from an amateur, sorry!!) Options
dvb247
#1 Posted : 28 December 2012 12:10:25
Rank: Beginner Level 3
Hi all,
I'm close to the point of clear coat or not to clear coat? as an amateur should I be considering it? if so can you show me a link to an easy way forward, the two .jpg files seem straight forward to me, although I'm thinking of not attaching my front suspension etc and clear coating more in parts rather than glued together at issue 77 time?
Decals
I've just read something about decals that mentioned Microset and Microsol? I want to get the decals to look right or it's ££££ down the drain and many hours of enjoyable modelling, so again is there a link to some good advice on applying decals?
Thanks in advance BigGrin
#2 Posted : 29 December 2012 23:26:04
I would say don't try clear coating unless you are experienced in spraying models. It's very easy to mess up, and that would totally wreck your model.
Wilfy the Sea Dog
#3 Posted : 30 December 2012 08:58:18
This page was generated in 0.147 seconds.
