162 Pages «<1617181920>»
IAN
#341 Posted : 03 January 2013 11:10:37
Hi Andy...
The unimax looks expensive, until you break down the price of each individual component, jig saw drill lathe etc...
and great work...
best regards,
Ian
Ian
Wish list: Bentley Blower
#342 Posted : 03 January 2013 22:27:20
IAN wrote:
Hi Andy...
and great work...
best regards,
Ian
Hi Ian, hadn't quite thought of it like that but I agree, break it down to component level and it turns out to be quite a fair price.....
#343 Posted : 03 January 2013 22:28:27
BigGrin Get well soon m8
Thanks Andy, getting there but it feels like a slow process..... I hate bugs......Cursing Cursing
#344 Posted : 04 January 2013 22:23:18
At last, finally feel well enough to get back to doing some work on the lady.... Have now done as much as I can on planking the 2nd deck and will finish when dummy gun supports are in place.... Also had a go at treenailing, first by drilling a .4mm pilot hole using a micro drill and inserting .3mm plastic fishing line coated in PVA..... fine sanded to finish. Can't decide whether to stain light or dark oak, will have to do some samples first and work out the best way of applying the stain.....BigGrin
#345 Posted : 04 January 2013 22:35:19
Finished fairing the hull and now started the infamous planking stage... Following Mr T's official build have made a start on the stern section... hopefully will finish this part off during the next session. Have to admit, found bamboo easy to manipulate but, will also add it is difficult to cut cross grain with a modellers knife. Cut to length using a razor saw.... much easier..... Should make cutting out of gun ports interesting.....Laugh
RobT
#346 Posted : 04 January 2013 23:30:47
Looks great.
You're right about the gun ports though. I think that will prove incredibly difficult. Unless the more experienced have any killer tips.
#347 Posted : 04 January 2013 23:43:04
RobT wrote:
Looks great.
Thanks for looking in Rob, appreciate your comments.... I was thinking along the lines of a hammer and chisel....LOL LOL
denissimo
#348 Posted : 04 January 2013 23:51:44
My method of cutting small square holes, is to drill a small pilot hole in each corner, and then cut out the hole very carefully with a cutting disc in a Dremel.
Model boats built so far:-
Billings Cutty Sark
Scratch built twin IC RC Vosper MTB.
Scratch built rc electric hybrid.
Scratch built rc IC hydrofoil (ran happily on snow as well as water!)
Plus numerous numerous RC planes.
Under construction
Sovereign of the Seas!
1200:1 HMS Victory (by Mantua)
The Battleship Yamato (seriously considering building as an RC model)
#349 Posted : 04 January 2013 23:59:07
Thanks for the tip Denissimo, I have a dremel and small cutting discs so I think a practice session may be called for..... Thanks for looking in....
#350 Posted : 05 January 2013 00:06:42
Blink Just remember to wear safety goggles when using these small cutting disc's as they can do a lot of damage to eyes and face if the shatterCrying
#351 Posted : 05 January 2013 00:10:48
Andy, that piece of advice is why a love this forum and the builders within it..... thanks M8..... Think you should post that tip under the know how section.....BigGrin
denissimo
#352 Posted : 05 January 2013 00:22:14
Alan, before I start cutting out, I'm going to build a few gun ports out of some spare scraps of bamboo, just to practice on.
Lots of steady hand practice BigGrin
Billings Cutty Sark
Under construction
Admiral Anti Spiral
#353 Posted : 05 January 2013 20:06:12
Great work on the planking alan, looks really clean! i had the same idea of drilling holes in the corners of the ports, or just drilling holes in the shape of the port, and using a rotary tool/dremel, though i'll have to buy one first ^^
Processing - Progressing
Previous builds: HMS Victory
#354 Posted : 05 January 2013 22:20:56
Thanks for the comments Admiral, appreciate it.... I found this blade in my Draper modellers knife set. It's like a razor saw, works well on bamboo but only on the forward or backward stroke depending on which way you insert it into the handle.... Gives a clean cut and just may help with the cutting out of gun ports.....
#355 Posted : 05 January 2013 22:26:34
Finally finished planking the stern section.... Sure glad I had the Dremel to help shape the profile.... Bamboo is awful to cut... even with brand new blades..... First fitting of hull planks tomorrow..... ...Cool Cool
#356 Posted : 07 January 2013 22:46:19
Have finally made a start on planking.... Taking it nice and easy and so far I like how it's coming along. Did find though I needed to pre-drill the pin holes with a .5mm drill in order to stop the planks from splitting. Think I am going to enjoy this part of the build, may not be saying that a few weeks in but we will see.......Blink Blink
#357 Posted : 07 January 2013 23:08:22
looking good.nice and tidy.
#358 Posted : 07 January 2013 23:13:20
Thanks for looking in Karl, appreciate your comments as always..... I fully intend to take my time on the planking and 2nd plank the lower hull with walnut..... Onwards we go.....
claret
#359 Posted : 07 January 2013 23:16:33
Looking really good.
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
#360 Posted : 07 January 2013 23:22:11
Claret
Thanks Claret, any news on your back issues and you getting started again?.....
Guest (8)
This page was generated in 4.356 seconds.
