Hi Trev. What you have done looks awsome  . It does look daunting but as you know just take your time and also you have made it look easy. I look forward to it  . Best regards. Mark
Hi Alan, Thank you for looking at my post,this is the type of job that once you start you must finish,good job I work in the Opticial industry as this tiling can play havoc with your eyes,but what a learning curve, the problem I found was you can lose track of where your heading,but you have got to try it. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Mark, Thank you for looking at my post,I will be posting more pictures as soon as I can on the tiling,bet you can't wait to start!!.I estimate it will take about 500 hours at my speed and may be cross eyed at the end but worth every bit of it. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi trev. The tiling looks fantastic. I think it gives a better look to the finished model. Along with your other modifications you should have a super victory at the end. Look forward to seeing more Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hi Ian, Thank you for viewing my post,I think as you it will give a better finish I just hope more members will take it up as good advise on tiling at the moment is a bit rare,so you have to follow your nose. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
 Rank: Pro   Groups: Joined: 04/05/2012 Posts: 362 Points: 1,089
That looks great Trev And you are faster then I am, I`m still doing the Keel
Hi Peter Thank you for looking at my post,so far it has taken 190 hours and I am nearly finished one side,just need to sort out the lower wale I'm planning on rebating and fitting over the copper tilies Regards trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
 Hi Trev your tiling looks a treat and I guess with your plans it will look even better Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy, I must thank you for taking time to look at my post,more pictures soon. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Trev as usual very good work  Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hi Mike, Thank you for looking at my post,good to hear from you,hope all is ok more pictures soon. Kind regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Joined: 09/02/2012 Posts: 569 Points: 1,675 Location: Scotland
great work there Trev, love all the detail to the wardroom, and you copper plating, in your post 55 what kind of lathe are you using.
MoMo
tf64 wrote:Hi Alan, Thank you for looking at my post,this is the type of job that once you start you must finish,good job I work in the Opticial industry as this tiling can play havoc with your eyes,but what a learning curve, the problem I found was you can lose track of where your heading,but you have got to try it. Regards Trev. Hi Trev, have taken the plunge and purchased the tile pack..... Hope you don't mind if I curse you with each tile laid....  .. Your work convinced me it is the look I would like on my Vic,,,,, when I get started on her... Regards Alan
 Rank: Pro   Groups: Joined: 01/01/2013 Posts: 149 Points: 459
Trev,Nice work Best regards, Reiner
Hi Mo, Thank you for looking at my post,in answer to your post the lathe I used for this type of work is the Unimmat Classic,you will find a few on this forum use it.This unit can mill horizontal and vertical also as a wood turning lathe,a jigsaw,a sander and a hand held drill and a bench drill,and that's not all. The Unimat was the start to my home workshop there are many accessories for you to expand the system still further,Mo it all fit's together,and turn's around just like the Lego the kid's have.I just love it the latest turning I have done is the fire buckets. I hope I have helped you in this reply. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Alan, Thank you for looking at my post,I am pleased to read that you are thinking of tiling your Victory,at the moment I have just finished one side some 200 hour's I know I am slow but it is well worth it. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Joined: 18/11/2012 Posts: 19 Points: 57 Location: Sutton, Ont., Canada
Hi Trev, Love your miniture furniture you did a fantastic job on the wardrooms. I may try to add a few of your ideas to my Victory if that is ok with you, I think it sure adds a nice touch. Lawrence
Hello Lawrence, Thanks for looking in on my build,I must say that I did enjoy building the wardroom or thought it is not to scale I really made it as I went along that,s part of the fun.Please copy anything you wish from my build,that will be fine with me.Hope to see your pictures some time. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Trev, thanks for the ok to use some of your ideas on my build. Is it possible for you to give me the measurments for the great looking table in your build. I forgot to congratulate you on your fantastic build, please keep the pictures coming. Regards Lawrence
Hi Lawrence, Just picked up your last post,sorry, do you still need the measurements or is it to late for me to you. All the best Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Guest (6)
