Joined: 06/06/2010 Posts: 566 Points: 1,657 Location: UK
Hi, Recently received this set of glue applicators made by Mr Hobby. Set includes, 1 very fine point, 1 flat spreader & 1 curved applicator plus a small pot for containing your CA. Not sure of the material but maybe some kind of PTFE, the glue CA literally just wipes from the end or if set you can flex the end & it just peels off. The fine tip is ideal for applying tiny amount of glue & the other two for for larger areas or spreading. The pot retards the drying time so useful for a whole modelling session. They also work with PVA & fillers, so really useful. Not cheap at about £9.00 a set but great if you are into AFV's especially with PE parts. Wilfy Wilfy the Sea Dog attached the following image(s):
Hi Wilfy. Thanks for the wright up on what seems to be a very useful set of tools Will have to get myself a set. Thanks and best regards. Mark
